Tools ouside of folder
jsweatherbie
Message 1 of 8
jsweatherbie
Hello, I'm trying to figure out how to get tools outside of folder.
When I program on powermill I "remove from folder" each cutter I use and I'm trying to just gather the ones outside of the folder
In this picture you can see my main tooling folder And then the tools outside of it all .
In a macro I'm trying to gather those tools and only those tools. I'm not trying to gather everything in "1600-TOOLING"
Replies (7)
Message 2 of 8
icse
I'm currently on the go so i could not test it in Powermill...
but you could do something like this:
entity list $tools = filter(folder('tool'), 'dirname(pathname(this)) == "Tool"')
Tested it today, works now 😉
Message 3 of 8
jsweatherbie
Yes sir!
Works as it should.
Normally you get it spot on! Thank you!!!
Message 4 of 8
jsweatherbie
Is this able to have a diameter sort ?
Message 5 of 8
icse
try this:
entity list $tools = sort(folder('tool'),'Diameter')
Message 6 of 8
jsweatherbie
I meant for what you had before like is it able to have a sort added to it like....
entity list $mytools = reverse(sort(filter(folder('tool'), 'dirname(pathname(this)) == "Tool"'), 'diameter')))
I doubt that actually works but you can see where I'm trying to go lol
Message 7 of 8
icse
I think you got a ')' to much at the end.
This should work:
entity list $mytools = reverse(sort(filter(folder('tool'), 'dirname(pathname(this)) == "Tool"'),'diameter'))
Message 8 of 8
jsweatherbie
I did haha I have troubles with the modifiers and what goes next
