PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Toolpath unexpected axis - how to fix
1 REPLY 1
Jason_McDaniel
146 Views, 1 Reply
Hi all. I have run into a similar issue where I am calculating a line projection toolpath for use on milling with a robot on a rotary table. I have to use .stl models. In some areas, the toolpath generated will contain some "cusps" in what should be a fairly smooth round section. In these areas, the tool axis will switch direction very abruptly. This causes problems with the robot. What causes this and how can I avoid it. Thank you.
Labels (4)
1 REPLY 1
In this case, the ideal is for you to send a copy of your project so that we can suggest improvements. Without having the project, it is a little difficult to know what will solve your problem.
One suggestion: Enable axis smoothing:
Rafael Sansão
Technology Administrators
