Toolpath option setting
jw.kim5
jw.kim5
Hi all,
Is it possible to turn on/off the default options when creating a toolpath?
For example, whenever create 3D Offset Finishing, I want to turn the 'Point separation distance' option off.
iamcdn79
You could create a macro using the following code to run from your ribbon toolbar
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "Finishing/3D-Offset-Finishing.ptf"
EDIT TOOLPATH POINTDIST 'MaxDistanceBetweenPoints.Active' '0'
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
jw.kim5
Thank you for replying.
Is also there a way to modify the ppm or mac file in PowerMill 2022 folder?
iamcdn79
Which ppm and mac are you referring to?
Windows 11 Pro
jw.kim5
Actually I have no idea which ppm or mac file can do this.
I don't know deeply about ppm or mac.
Some other co-worker suggested about fix ppm or mac if there is option about I was mentioned.
