Tool Tree Set-Up Sheet
Message 1 of 59
I am looking for help to make a macro that will take all of my tools on the tool tree, organize them in numerical order and then export them into a format that is printable.  This would be beneficial when I have a multi-program Powermill file, so that the operator only has to look at one tooling list when setting up the machine for all the programs.
This info into printable form:
Thanks for any help.
Replies (58)
Message 21 of 59
5axes
Last modification :
The HTML document is now load into PMILL directly and if you clic on the image the tool definition is Open . Usefull to make a quick review of your tool (Ie to add a missing tool number or modify a wrong tool holder definition) :
Message 22 of 59
Rui_Ramos
hello,
Great Macro!!
could you please upload de file again, it says "file is corrupted..."
thanks
Message 23 of 59
5axes
One copy of the last "release" can be found there : https://knowledge.autodesk.com/fr/community/article/99886
Message 24 of 59
Rui_Ramos
Greetings 5axes,
is it possible to change the macro (fantastic macro by the way!!) to list only the tools of the selected Ncprograms? can you please help me with that issue?
thanks in advance,
have a nice day
Rui
Message 25 of 59
5axes
Replace the line :
FOREACH tp IN folder($a_f) {
by
IF NOT ENTITY_EXISTS(entity('ncprogram', '')) {
 MESSAGE ERROR "No Ncprogram activated"
 RESUME
FOREACH Tl IN list_nctools(entity('ncprogram', '')) {
ENTITY $tp=entity('Tool',$Tl)
Message 26 of 59
Rui_Ramos
5axes,
thanks for the help,  but I wanted to list the tools of the selected Ncprograms, not the activated Ncprogram...Maybe I´ve explained wrong!!
it´s listing only the activated Ncprogram.
thanks
Message 27 of 59
5axes
ok
so Replace
Function Main() {
by
Function Main( STRING $Selected_NCP) {
And
by
FOREACH Tl IN sort(list_nctools(entity('ncprogram', $Selected_NCP))) {
(In this case you don't need to test if  an activ ncprogam exists)
Add in your ncprogram.xml file the line
<button command='MACRO "Export_Outil_NCProg_Html" "%s"' label="Export HTML" />
to launch the macro via the user menu
Message 28 of 59
Rui_Ramos
IT GIVES AN ERROR!!
Message 29 of 59
5axes
This macro MUST be launch via the user menu ( ncprogram.xml)
Message 30 of 59
Rui_Ramos
5axes,
Thank you very much !!
have a nice day!!
Rui
Message 31 of 59
5axes
If the Tool.identifier is not Equal to the tool.name you can have some issues with my last solution : https://forums.autodesk.com/t5/powermill-forum/macro-looking-for-a-smarter-solution-to-select-a-give...
So the new solution :
replace
        $ToolName = $tp.name
by
// build the expression
STRING $expr = "RootType=='nctoolpath'"
// get the list of tool (sorted in the NCProgram order)
STRING LIST $tl_list = extract(filter(components(entity('ncprogram', $Selected_NCP)), $expr), 'tool.name')
INT Nb=remove_duplicates($tl_list)
/// List every tool of the list
FOREACH ToolName IN $tl_list {
    ENTITY $tp=$entity('Tool',$ToolName)
Smiley Wink
Message 32 of 59
Rui_Ramos
Greetings 5axes,
how do I do that, I´m struggling here to launch this macro....Smiley Frustrated: , with no success!!
thanks
Message 33 of 59
Is there a way to use the tool number in the NC programme instead of the tool??
Message 34 of 59
rob_carri
hi
@5axes, please, you could modify the macro only for the tools that you select
thank you
Message 35 of 59
5axes
If you are using a release 2018 or 2019 it's quite simple because you can use the function explorer_selected_entities()
in this case replace in the macro the existing  FOREACH   loop  by  :  FOREACH tp IN explorer_selected_entities() {
/// Liste tous les outils
// FOREACH tp IN folder($a_f) {
As you can have in the explorer some selected entities which are not some tool element you should add a test in the loop to test if the entities are some Tool definition :
        STRING Root = tokens(pathname($tp), "\")[0]
        IF $Root != 'Tool' {
        	BREAK
Message 36 of 59
gosmann.andreas
How do i start the Marcro with Macro Button without usermenu?
Message 37 of 59
wm_pm
Hello everybody,
can this macro be changed so that it only outputs the tools in the active folder?
Many Thanks
// Ouvre un fichier pour écrire le tableau outil (Type HTML)
// Modif 06/06/2016 : Export via ecriture fichier
DIALOGS MESSAGE OFF
DIALOGS ERROR OFF
ECHO OFF DCPDEBUG UNTRACE COMMAND ACCEPT
//Check the name of the project and if it have been already save
STRING $projectName = project_pathname(1)
STRING Msg = ""
STRING Cmd = ""
IF $projectName == "" {
$Msg = "Impossible de créer les documents pour l'export, vous devez d'abord sauver le projet !"
MESSAGE ERROR $Msg
MACRO ABORT
//Création d'un répertoire Export_ExportTool dans le Projet en cours
// Répertoire Export ExportTool
STRING $ExportToolTempDir = project_pathname(0) + "/Werkzeugliste"
MKDIR $ExportToolTempDir
STRING $ExportToolImg = ''
STRING $ToolName = ''
// Definition Fichier Html
STRING $Ligne=''
STRING $Fichier=$ExportToolTempDir+'/Werkzeugliste.html'
//Ouverture fichier
FILE OPEN $Fichier FOR WRITE AS filename
$Ligne = "<html>"
FILE WRITE $Ligne TO filename
$Ligne = "<head>"
$Ligne = "<title>Export outil</title>"
$Ligne = "</head>"
$Ligne = "<body lang=DE>"
$Ligne = "<H1>Werkzeugliste $project.orderno $projectName </H1>"
$Ligne = "<table border=1 cellspacing=1 cellpadding=1>"
// Première ligne
$Ligne = "<TR>"
$Ligne = "<H2><TD>Bild</TD><TD>Name</TD><TD>Nummer</TD><TD>Durchmesser</TD><TD>Typ</TD><TD>Eckenradius</TD><TD>Ausspannlänge</TD><TD>Werkzeughalter</TD></H2>"
$Ligne = "</TR>"
FOREACH tp IN folder('Tool') {
// Depuis les Outils
$Ligne = "<TR>"
// Image
$Ligne = "<TD>"
$Ligne = '<div align="' + 'center"' + '>'
// CREATION IMAGE
$ExportToolImg = $ExportToolTempDir + "/" + $ToolName + ".jpg"
$ExportToolImg = REPLACE($ExportToolImg," ","_")
$Cmd='FORM RAISE TOOLASSPREVIEWFORM "' + $ToolName + '"'
DOCOMMAND $Cmd
/// WAIT FORM Indispensable car sinon la Macro plante
// Il faut attendre la forme pour executer la suite
/// MACRO PAUSE "Outil $ToolName : $ExportToolImg"
WAIT FORM
// Generation Tool Preview
$Cmd="EXPORT TOOLASSEMBLYPREVIEW FILE " + $ExportToolImg
DOCOMMAND $Cmd
YES
FORM CANCEL TOOLASSPREVIEWFORM
//<img style="margin: -4px 400px -4px 5px" src="c:/Temp/vue.jpg" alt="ScreenShot" height="70%" />
$Ligne = '<img src="' + $ExportToolImg + '" alt="' + $ToolName + '"' + 'height="' + '10%"' +' />'
$Ligne = "</div>"
$Ligne = "</TD>"
// Infos Outils
$Ligne = "<TD>"+$tp.name + "</TD><TD>" +$tp.Number.Value + "</TD><TD>" + round($tp.Diameter,3) + "</TD><TD>" + $tp.Type+ "</TD><TD>" + round($tp.TipRadius,3)+"</TD><TD>" + round($tp.Overhang,3) + "</TD><TD>" + $tp.HolderName + "</TD>"
$Ligne = "</TR>"
$Ligne = "</table>"
$Ligne = "</body>"
$Ligne = "</html>"
FILE CLOSE filename
MESSAGE INFO "Export fichier : $Fichier"
// Ouverture fichier avec application associée
ole fileaction 'open' $Fichier
Message 38 of 59
5axes
Faster solution for large tool list
VIEW ANIMATION TIMELIMIT "0"
Message 39 of 59
rob_carri
good morning
please do not get the macro work with the selected nc programs. someone can help me I have 2 versions. the difference is that one takes the description instead of the name of the holder
Message 40 of 59
rob_carri
all I want is to insert a column to the original macro and specify the name of the program that uses the tool
