PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Tool ID Parameter for setup sheets
7 REPLIES 7
Message 1 of 8
528 Views, 7 Replies
Hi all.
I'm looking for the parameter that holds the value of tool ID.
That can be found on the cutting data Tab under Tool ID.
Probably obvious but I cant see it?
7 REPLIES 7
Message 2 of 8
cfastNJWK6
Message 3 of 8
in reply to: cfastNJWK6
Sorry that's not working, returns a blank field.
Is there any additional code to put at the front, e.g. for tool name I have {tool.name}
Here's what I'm expecting.
Message 4 of 8
cfastNJWK6
What about ${tool.Identifier}.  I have both in different areas of a setup sheet.
Message 5 of 8
That also returned nothing, do you have that string in a Excel spreadsheet?
Message 6 of 8
Looks like that parameter isn't included in the PLUG-IN for set up sheets..... Oh well
Message 7 of 8
cfastNJWK6
You are using a setup sheet plug in?  The parameters I sent work with the native PowerMill setup sheets.  I am using them and they are outputting the correct data.  If you are using a plug-in, you should be able to edit the plug-in to allow these parameters...
Message 8 of 8
Yes I'm using the plug in "PowerMILL Excel SetupSheet plugin" that writes to Excel files, I find it much simpler than editing HTML etc.
unfortunately I don't have a clue on how to amend the parameters for the plug-in.
