PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
The Parameter's Name of Single Blade Finisihing Cut Direciont?
1 REPLY 1
hx
86 Views, 1 Reply
What is the variable name for this parameter?
1 REPLY 1
icse
in reply to: hx
be sure the form is raised
print par $widget('SFBlade.Shell.SWBlade.CutDir').Value
to change the parameter you can use this:
MODE BLADE_CURVE_DEF PAR CUT_DIRECTION CLIMB
MODE BLADE_CURVE_DEF PAR CUT_DIRECTION CONVENTIONAL
