Take the coordinates of each point in the boundary. as the picture shows。How to get with the macro
The first half of a possible solution (my first Custom Software Core program)
Imports Autodesk.ProductInterface.PowerMILL
Imports Autodesk.Geometry
Imports Autodesk.FileSystem
Module Module1
Sub Main()
Dim PMill As New PMAutomation(Autodesk.ProductInterface.InstanceReuse.UseExistingInstance)
Dim session As PMProject = PMill.ActiveProject
If session.Boundaries.ActiveItem.Exists Then
Dim P As List(Of Polyline) = session.Boundaries.ActiveItem.ToPolylines
Dim f As New File(session.Directory.Path + session.Boundaries.ActiveItem.Name + ".dat")
Dim sXYZ As String = ""
For Each i1 In P
sXYZ &= Str(i1.Count) & " "
Next
sXYZ &= vbCrLf
For Each i1 In P
For Each i2 In i1
sXYZ &= i2.X.ToString & " " & i2.Y.ToString & " " & i2.Z.ToString & vbCrLf
Next
Next
f.Create()
f.WriteText(sXYZ)
MsgBox(session.Directory.Path + session.Boundaries.ActiveItem.Name + ".dat" + " created")
Else
MsgBox("Active Boundary missing")
End Sub
End ModuleThe program connect to active Powermill, get active boundary, convert to polylines, write it the project folder (file name is the same as active boundary+.dat)
The first line contains the number of points, the other rows contain the coordinates.
Sample macro for reload points from file:
FUNCTION MAIN {
IF project_pathname(0) == '' {
MESSAGE INFO 'Pls. save the project'
RETURN
IF NOT entity_exists('boundary','') {
MESSAGE INFO 'Pls. select boundary'
RETURN
STRING ActiveBoundary=entity('boundary','').name
STRING datFile=project_pathname(0)+'/'+$ActiveBoundary+'.dat'
IF NOT file_exists($datFile) {
MESSAGE INFO $datFile+' not found'
RETURN
STRING B1=""
STRING LIST B2={}
FILE OPEN $datFile FOR READ AS input
FILE READ $b1 FROM input
FILE READ $b2 FROM input
FILE CLOSE input
STRING LIST B11=tokens($b1)
INT LIST BoundarySizes={}
INT PointsNumber=0
FOREACH I IN $B11 {
$PointsNumber=$PointsNumber+int($i)
INT k=add_last($BoundarySizes,$PointsNumber)
IF $PointsNumber != size($B2) {
MESSAGE INFO $datFile+' wrong data'
RETURN
STRING NewBoundary=$ActiveBoundary+'_reload'
CALL NewName('boundary',$NewBoundary)
FOREACH I In $B2 {
STRING LIST XYZ={}
$XYZ=tokens($i)
IF size($XYZ) != 3 {
RETURN
GRAPHICS LOCK
CREATE BOUNDARY $NewBoundary SKETCH FORM BOUNDARY
EDIT BOUNDARY $NewBoundary PRIVATE NO
EDIT BOUNDARY $NewBoundary AUTOREPLAY NO
EDIT BOUNDARY $NewBoundary CURVEEDITOR NOGUI START
CURVEEDITOR MODE LINE_MULTI
STATUS GRID OFF
INT K=0
FOREACH J IN $BoundarySizes {
WHILE $k < $j {
STRING LIST XYZ={}
$XYZ=tokens($b2[$k])
REAL X=real($XYZ[0])
REAL Y=real($XYZ[1])
REAL Z=real($XYZ[2])
MODE COORDINPUT COORDINATES $X $Y $Z
$k=$k+1
CURVEEDITOR LINE_MULTI CLOSE
CURVEEDITOR MODE DEFAULT
CURVEEDITOR FINISH ACCEPT
Yes
EDIT BOUNDARY $newBoundary ACCEPT BOUNDARY ACCEPT
GRAPHICS UNLOCK
MESSAGE INFO 'Success'
FUNCTION NewName(STRING EntityType,OUTPUT STRING NewName)
IF NOT entity_exists($EntityType,$NewName) {
RETURN
$NewName=new_entity_name($EntityType,$NewName)
