Surface Finish Defects on Mould (Banding / Waviness) – PowerMill Raster Finishing + Point Distribution
anto_joseph4HH2K
Message 1 of 24
anto_joseph4HH2K
I am experiencing consistent surface finish issues when machining a mould surface using PowerMill finishing toolpaths. The issue appears as visible banding and wavy patterns across the machined surface, particularly noticeable under light reflection.
-Can Redistribute output type introduce surface deviation significant enough to cause visible banding on mould-quality surfaces?
-Is Point Separation Angle (1°) known to create non-uniform tool motion leading to ripple artefacts?
-Recommended tolerance and mesh factor values for high-quality mould finishing?
-Are raster strategies inherently unsuitable for this type of surface compared to morph / spiral / flowline?
Replies (23)
Message 2 of 24
iamcdn79
turn on the 'point separation distance' to give it more points and play with the values. Start at a high number and then bring it down if it doesn't improve
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 3 of 24
rich11
With Redistribute i found the tolerance factor need to be really low, the mesh is ok at 0.1 or lower but the factor needs to be 0.01 or less
Message 4 of 24
icse
Isn't the factor relative to the tolerance? 0.03 seems very low, what's your tolerance?
Message 5 of 24
rafael.sansao
Your tolerance factor and mesh factor values are VERY low.
If you are using a toolpath tolerance of 0.01 mm, and your tolerance factor is set to 0.03, PowerMill is effectively calculating with an internal value around 0.0003 mm. That is unnecessarily small and can actually create unstable point distribution and visible surface artefacts.
I would recommend starting with:
Toolpath tolerance: 0.005 ~ 0.01 mm (0.005 mm should already produce an excellent mould finish)
Point Distribution: Redistribute
Tolerance Factor: 0.3
Mesh Factor: 0.2
Leave all other point distribution options disabled
This settings should generate a very good surface finish.
Also keep in mind that strategies such as Parametric Offset and 3D Offset can become distorted during calculation because of the boundary definition. Make sure the boundary itself is not introducing the issue.
A good way to verify this:
If the boundary is the source of the problem, you should be able to visually see the waviness directly in the toolpath when displaying the toolpath points.
Rafael Sansão
OptiNC - www.optinc.tech
Message 6 of 24
rich11
I no longer use it myself, I use tolerance and keep arcs, but turn off the arc support in the post.
for finish, tolerance = 0.1 and mesh 0.1/0.05
I get a faster calc and less vertical noise
Message 7 of 24
anto_joseph4HH2K
I tried tweaking all parameters including point distribution,tolerance and mesh, nothings improving the fisnish as shown, one thing i noticed is that the ripples goes away when i use a smaller ball nose,(6mm) and gets worse when i use a (16mm)
Message 8 of 24
navya_gelli
Hi @anto_joseph4HH2K ,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
Navya | Community Manager
Message 9 of 24
anto_joseph4HH2K
I still havn't resolved the issue, I tried all suggestions from the community.I am still tweaking different parameters hoping to find a soluton
Cheers
Anto
Message 10 of 24
nguyenthinhvt95
This is my favorite setting, and the result is perfect. You can give it a try.
P.S. The calculation time and collision checking take a bit longer, but the surface finish is excellent.
Message 11 of 24
rich11
update
chatting with AI.
I did some tests and I like the results, redistribute at 0.5, Tol at 0.005 and mesh at 0.01.
Apparently mesh should be twice the TOL.
Message 12 of 24
navya_gelli
Hi @anto_joseph4HH2K,
Did the info from nguyenthinhvt95 and rich11 help answer your question?
If it did, it’d be great if you could click the "Accept Solution" button so others can easily find it too.
If you’re still needing more help, feel free to share an update here. The community will be happy to jump in with any next steps to help you get where you need to be.
Message 13 of 24
TK.421
Why should mesh factor be twice the tolerance?
@navya_gelli please dont start spamming posts about solutions. if autodesk wants to be "helpful", give us new functionality. otherwise, please stay out of our way on here.
the numbers never lie
Message 14 of 24
rich11
To be honest it is something the Copilot AI picked up on.
So far I have done three job with this setting, no issues yet, very small programmes in comparison, very stable z moves.
I have yet to try it on a larger job
Message 15 of 24
TK.421
ok. i've always made it the same as my tolerance, but for no specific reason other than i thought it seemed like the right way to do it.
i've got a 5axis cut that is doing the herky-jerky so i'll play with that too & see if it helps improve the motion any.
Message 16 of 24
rich11
you thinking redistribute and the tolerance factor 0.5?
I might of had duff info when I started out, that the mesh of 0.1 is 10% of tolerance.
That made the tolerance of 0.1 with a mesh setting of 0.1 made the mesh 0.01 as an example.
Message 17 of 24
TK.421
i know our heidenhain control likes points, so i made my tolerance factor .25 and the point separation distance .125 (inches), always using redistribute for that control.   my coworker told me to tighten that up even more, so now i cut those numbers in half & we'll see what that does.  I'll ask him when he gets in what the use is for mesh factor, if that would help or not in this case.
Message 18 of 24
rich11
Never had to use point separation distance.
On one programme I did with 0.5 tolerance factor I drew a circle on the tool path points to check cusp heights. I found all was good in this case inline with the tolerance.
For angled shut out work I will be testing 0.002 tolerance, mesh 0.004 and factor still 0.5 (small local progs normally)
I am assuming a factor of 0.25 is just increasing points/programme size and the start to stress some machines out at the moment.
I will no longer be using a tolerance factor of 0.1, after having drawn those points up.
good luck with your tests.
Message 19 of 24
TK.421
let's compare notes after this. maybe @Sean570 can shed more light on this
Message 20 of 24
ahorwood
This has been a very good, informative discussion.
