Sorting Drill Holes by Depth
p.valente
p.valente
Hi all,
There is any way to organize drilling holes by depth ?
When I have lots of holes, the post-processor create many drilling cycles in NcProgram. Because there is no organization by depth. I have 3 holes with same depht but on diferent places, I need powermill drill the 3 holes together, on this way only 1 cycle def is created on NcProgram.
Thanks in Advance
Best Regards
Cobra.007
Hey,
I think there is a way to achieve this.
First make sure that the holes in the "Hole Feature sets" are ordered by diameter and depth.
   This can be done with a macro.
Then in the drilling toolpath, select order "Use explorer tree order"
That should do it, but I did not test it yet
Greetings
karan30782
Hi !
To get that result. You just need to ...
This way .. you get one drilling cycle in ncprogram for same diameter.
Cheers !!!
p.valente
I do that all time. The problem is diferent depths.
Example: Z-15. + Z-20. + Z-15. it make 3 cycles. I need both Z-15 in same line/cycle. For this happen I need organizate holes by depth. And get this Z-15. + Z-15. + Z-20.
The Top of Hole is important but in this case I need "depth of hole"
Thanks for help.
rafael.sansao
With the featureset active, run this. Toolpaths must be calculated after that.
It must do what you want.
EDIT FEATURESET ; SORT "depth"
EDIT FEATURESET ; SORT "diameter"
Rafael Sansão
OptiNC - www.optinc.tech
