Sorting a entity list
jsweatherbie
jsweatherbie
Hey everyone I'm trying to get my macro to work and it's either not the results I need or errors lol....
I have an entity list that I'm looking to sort the tool.type
This is what I have.....
***NOTE: Might have spelling errors but that's not my problem ***
//Tool folder
string $db = 'Tool\'
//Empty lists
string list $sortedTools = {}
Entity list $myTools = reverse(sort(folder($db),'$tool.type'))
foreach $tool.type IN $myTools {
//MACRO CONTINUES....
ondrej.mikulec
This is tricky. It looks like Powermill macros poorly handles (ENUM) types in function for lists. In you macro there are some mistakes, but even after I have corrected them, I was still unable to sort the tools by the 'Type'.
I'm not exactly sure what is your plan but still here is an alternative where the tools are sorted into folders according to its types and then sorted by names inside.
//Tool folder
FOREACH $tl IN folder($db) {
	IF NOT folder_exists('Tool\'+$tl.Type) {
		CREATE FOLDER "Tool" ${$string($tl.Type)}
	EDIT FOLDER ${'Tool\'+$tl.Type} INSERT $tl LAST
FOREACH $fld IN get_folders('Tool') {
	FOREACH $tl IN sort(folder($fld),'Name') {
		EDIT FOLDER $fld ORDER ${$fld + "\" + $tl.Name} LAST
icse
this should work:
entity list $tools = {}
string list $types = sort(apply(extract(folder('tool'),'Type'),'string(this)'))
int $removed = remove_duplicates($types)
foreach $type in $types {
	foreach $t in filter(folder('tool'),'this.Type =="' + $type + '"') {
		int $index = add_last($tools,entity('tool',$t.Name))
string $msg = ''
foreach $t in $tools {
	$msg = $msg + $t.Name + "   " + $t.type + CRLF
message info $msg
