PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Slow Transitions Between Different Toolpath Strategies
11 REPLIES 11
Message 1 of 12
676 Views, 11 Replies
Some of our workstations are experiencing painfully slow transitions between different toolpath strategies. (For example: when going from a Model Area Clearance to a Deep Drill strategy) Sometimes it takes well over 30 seconds to open another existing toolpath strategy.  However, this isn't the true on all workstations, we have several.  Our IT department can't figure it out.  Can anyone point me in the right direction or what settings to check?  Thanks
Workstations are up to date using PowerMill 2021.1.1
Tags (1)
11 REPLIES 11
Message 2 of 12
BearArms
Yes we noticed it also, almost painful when in a hurry. I wish they would fix it, it's very slow this build, 2021.
Message 3 of 12
__Luca__
Try updating the graphics drivers
Message 4 of 12
l.ponsaerts
Seems to be an old issue, happens on some PC's only. See attachment.
Message 5 of 12
BearArms
in reply to: l.ponsaerts
It didn't help for us.
Message 6 of 12
Jonathan.Artiss-DSI
Update your graphics driver, set the manage 3D setting to 3D app - Visual Simulation.
Empty your %TEMP% directory.
Shut off anti virus.
Ensure you have full permission under the Windows account.
Jonathan Artiss
Senior Applications Engineer | DSI
Autodesk Expert Elite member
DSI, Design and Software International Autodesk Gold Partner
Message 7 of 12
in reply to: Jonathan.Artiss-DSI
Jonathan,
Where do I find this "set the manage 3D setting to 3D app - Visual Simulation"?
I haven't been able to find that specific setting on my video card settings or anywhere else.
Message 8 of 12
Jonathan.Artiss-DSI
Open the NVIDIA Control Panel and go to the manage 3D setting.
Jonathan Artiss
Message 9 of 12
I.T.  did all those changes and no difference.
Message 10 of 12
l.ponsaerts
in reply to: BearArms
Stop Windows Firewall and virusscanner. and try again.
You never know...
Message 11 of 12
Thanks, but our IT department won't allow that.
Message 12 of 12
Jonathan.Artiss-DSI
Can they pause the virus scan so that you can test this?
The two biggest problems that I find that are difficult to diagnose are virus scanners and Windows user permissions.
The  scanner can slow or block PowerMill from accessing files on the C drive. If this is the problem, you will need IT to add PowerMill to the scanners white list. This doesn't always work and sometimes you just need to swap out the virus scanner with something that is compatible.
As for user permissions, you can test this by having IT log you in as admin. Test to see if it fixes the slow downs. If it does, they need to grant the user permissions to the PowerMill directory on the C drive.
Jonathan Artiss
