Setups - order of the toolpaths
deactivated_JanNavratil
are we able to get the order in which are toolpaths in setup?
The standard way do not work, I still see the order in which toolpath were in standard tree and not in the setup.
Can you please advise?
Jan
urizenYHS3W
components(entity('setup','name'))
Thank you !
iamcdn79
Do you know how to get the toolpath dialog list of toolpaths order to match the order of the toolpaths in the setups?
Right now the dialog list is in order the of when the toolpaths were created.
In the pic I want toolpath 2651 to show up first in the dialog list then #7 #2652 #8 etc.
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
urizenYHS3W
Cycle through setups and get the toolpaths, add each name to a list.
STRING LIST li = {}
FOREACH s IN folder('setup') {
  FOREACH t IN components(s) {
   int x = add_last(li, t.name)
STRING LIST tps = INPUT ENTITY MULTIPLE TOOLPATH "pick tps" "" $li
iamcdn79
Ok thanks, that helped but how do I select just that selected setup toolpath?
In my previous macro I had
	STRING TOOLPATHName=''
 ENTITY LIST $Selected_Toolpath = INPUT ENTITY MULTIPLE TOOLPATH "Select Toolpaths For Sub Program List"
 FOREACH $tp IN $Selected_Toolpath {
 ACTIVATE TOOLPATH $tp
But now I have to change that to something else, I tried this but it goes through every toolpath not just the selected one
STRING LIST li = {}
 FOREACH $tps IN $li {
  ACTIVATE TOOLPATH $tps
Windows 11 Pro
urizenYHS3W
Activate the setup you want. Then
STRING LIST n = extract(components(entity('setup','')), 'name')
STRING LIST tps = INPUT ENTITY MULTIPLE TOOLPATH "pick tps" "" $n
