Rotary Z axe starts to high
Szigeti.Eduard
Szigeti.Eduard
I have created an area clearing toolpath and  I put up the stock on the rotary and cleared the Z and A on the surface of the stock. The problem is that when I run the program the cutter starts cutting around 20mm above my Z level and stops way above the limit I set in powermill.  This doesn't happen when I run a similar toolpath on the 3 azes machine.  Anyone knows what happened? Thanks
istan
Yes I know what happened.
PS: The answer has the same level of information as the question 😉
