Hi @tanghSMNKH
Start by activating the PowerMill Robot add in:
Go to the menu File, then Options
The next dialog allow launching the addins, select one, then click on the A button, that switch Enabled/Disabled.
You eventually need to change the view layout of PowerMill to enable the plugin window
Once all is done, you can take a look at the PowerMill Robot Interface, and see the available posts:
As you can now see it, Denso is not part of our library.
When you are looking for a post, or post modifications, you can contact one of our partners.
Given our partners can provide more localized support, we would encourage you to investigate the partners in your area, which can be done through our Services Marketplace.
https://customersuccess.autodesk.com/partners/search?search=post%20processor&locations[]=detect
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
