PowerMill Forum
Welcome to Autodeskโ€™s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Ribbon DropDown menu trick
40 REPLIES 40
Message 1 of 41
dsmits
5667 Views, 40 Replies
some Kudos would be great ๐Ÿ™‚
after button 1 & 2 you can pretty much just copy and paste your ribbon button/macro/cmd right in order like you normally would edit your ribbon (notepad++). for button 1 and 2 you need to keep this format to a point.
Note---you cannot edit your tree in power mill, you will have to do your changes in notepad and import your ribbon in. But after you import it in you can move your dropdown to another ribbon.
so i would finish your drop down and then move to your desire ribbon
Note-- you can make drop downs from other dropdown items but does get pretty confusing. ill post that one too if i still have.
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<entry application="PowerMill" application_version="1" type="uiRIBBONBAR" version="1">
  <entry type="uiCATEGORY">
    <resource key="uiLABELSTRING" value="TREE"/>
    <entry type="uiPANEL">
      <resource key="uiLABELSTRING" value="GROUP NAME"/>
      <resource key="uiRIBPANELALIGNMENT" value="false"/>
      <entry base_widget="Ribbon.Home.Macro.MacroRun" recursive="false">
        <resource key="uiLABELSTRING" value="THIS IS NUMBER 1"/>
        <resource key="uiBITMAP" value="CETEXTAROUNDCIRCLE"/>
        <resource key="uiCOMMAND" value="print = 1"/>
        <resource key="uiDYNAMICHELP" value="Text"/>
        <entry type="uiICONBUTTON">
         <resource key="uiLABELSTRING" value="This is number 2"/>
          <resource key="uiBITMAP" value="ROUTING"/>
          <resource key="uiCOMMAND" value="print = 2"/>
          <resource key="uiEDITTYPE" value="CommandButton"/>
        </entry>
      </entry>
          <resource key="uiLABELSTRING" value="This is Number 3"/>
          <resource key="uiCOMMAND" value="print = 3"/>
        </entry>
          <resource key="uiLABELSTRING" value="This is Number 4"/>
          <resource key="uiCOMMAND" value="print = 4"/>
        </entry>
          <resource key="uiLABELSTRING" value="This is Number 5"/>
          <resource key="uiCOMMAND" value="print = 5"/>
        </entry>
          <resource key="uiLABELSTRING" value="This is Number 6"/>
          <resource key="uiCOMMAND" value="print = 6"/>
        </entry>
      </entry>
    </entry>
  </entry>
</entry>
ribbontree.pngplease like for sharing
40 REPLIES 40
Message 21 of 41
Beta_Librae
in reply to: dsmits
Is that how you created the slide bar?
Kind Regards,
Not cnc, you can call me Peabrain
Message 22 of 41
barr.jarryd
in reply to: Beta_Librae
In regards to this, my ribbons keep defaulting back to the Home ribbon when I close out of a window; toolpath for example.
Is there a way to set it so that my Custom toolbar is the default to return upon closing a window?
Thank you
Jarryd Barr
Message 23 of 41
danmic7JH66
in reply to: barr.jarryd
Thank you
Jarryd Barr
Not that I'm aware of but you can add this command to the end of your macros to go back to your custom ribbon.
FORM RIBBON TAB UICATEGORY
Message 24 of 41
barr.jarryd
in reply to: danmic7JH66
Thank you
I will restructure to run just macros so that it will work this way.
Thank you
Jarryd Barr
Message 25 of 41
BS_agru
@Beta_Librae wrote:
Curious how you made the slide bar shown in this thread. I think it could be a pretty cool addition to the software. What are you using it for?
someone figured out how to add a Slidebar?
Message 26 of 41
Hello!
I don't have much experience with .XML files. But what is this code about? could you share an image or video of the final result?
I am not understanding the result.๐Ÿ˜–
Where did you insert this text in the option_menu.xml file inside the ribbon_customisation.xml file?
Message 27 of 41
Beta_Librae
in reply to: BS_agru
 Sorry, I think it's possible, but I don't have anything that works. Didn't ever really get a clear answer about how to create it, and I haven't figured it out myself.
Kind Regards,
Message 28 of 41
BS_agru
...dito...๐Ÿ™„
Message 29 of 41
johnc4668
in reply to: dsmits
@dsmits @barr.jarryd @Beta_Librae @danmic7JH66   This post has me intrigued and i cant quit this! Take a look at my xml file here if you would. I have the drop down button on my ribbon but i am stuck on how to add more macro buttons to the drop down. Heres part of my xml and my ribbon screen shots:
</entry>
<entry type="uiRIBMENUBUTTON">
<resource key="uiLABELSTRING" value="Drilling Methods"/>
<entry type="uiPUSHBUTTON">
<resource key="uiLABELSTRING" value="3ax Dm Standard Steel"/>
<resource key="uiBITMAP" value="STRATEGY__METHOD"/>
<resource key="uiCOMMAND" value="MACRO &quot;Z:\Software\PowerMill\Macros\3ax Dm Standard Steel.mac&quot;"/>
<resource key="uiUSERDATA" value="Z:\Software\PowerMill\Macros\3ax Dm Standard Steel.mac"/>
<resource key="uiEDITTYPE" value="MacroButton"/>
</entry>
</entry>
Message 30 of 41
glaubergimenez
in reply to: johnc4668
I got this somewhere on this forum. Merits for the Creator.
Import this XML and edit in notepad ++, how many instances would it solve?
Then move the Menu according to the image.
Message 31 of 41
BS_agru
look at my Sample.xml
Message 32 of 41
rui_rita
Hi @johnc4668
this part is a button, just  copy/paste and change values as many buttons you need to add
</entry>
Os melhores cumprimentos | Best regards
Rui Rita
________________________________
NEWCAM, Lda.
Message 33 of 41
johnc4668
in reply to: glaubergimenez
Yes, this was the same file i got it from but didnt need the command button "my button 1". I want to add more macro buttons "my button 2" to this drop down but not sure how to edit the xml file. Can you copy buttons in the customise ribbon window in powermill, didnt think you could?
Message 34 of 41
glaubergimenez
The file that @BS_agru sent, I think is more prepared for what you need, but without icons. It's a very interesting option once you get familiarized with the menu. ๐Ÿ‘๐Ÿ‘
Message 35 of 41
rui_rita
@johnc4668  you have to edit your xml file in text editor.
and any change to the dropdown menu you should always use a text editor. any change you make in powermill window, you could be messing  with the dropdown menu.
Rui Rita
NEWCAM, Lda.
Message 36 of 41
johnc4668
in reply to: dsmits
@glaubergimenez @rui_rita @BS_agru  Got it! You guys rule! Love this forum. All good now
As someone previously said i too am playing with powermill buttons like a kid now ๐Ÿ™‚
Message 37 of 41
BS_agru
๐Ÿ‘ Thanks especially to @dsmits & @NathanWoodward !
Message 38 of 41
PGI-49
in reply to: dsmits
Is it possible to directly call in a strategy template and what is the code? I can't seem to get it to go for some reason.
Message 39 of 41
tiago.coelhoMEKWZ
in reply to: dsmits
Thanks for your help!
One sugestion, use 'Ribbon.FeatureGroup.Draw.DrawOptions' instead 'Ribbon.Home.Macro.MacroRun' if you don't want your drop down button "clickable".
It is possible to create a tree like that
just do an base_widget inside another.
Message 40 of 41
Hello Sir,
I am trying to make drop down menu with child button. I attached my sample file here. But it throws error  "failed to import the ribbon customization". please do the needful.
Technology Administrators
