return value of Block locked state
jjat-wang
jjat-wang
I want to know if the block is locked.
Because the value can still be changed by the macro
BOOL lockXmin=$widget('RoughBlock.LimitFrame.LockMinX').Value
BOOL lockXmax=$widget('RoughBlock.LimitFrame.LockMaxX').Value
BOOL lockXLen=$widget('RoughBlock.LimitFrame.LockLenX').Value
// Toggle block Xmin lock state
IF $widget('RoughBlock.LimitFrame.LockMinX').Value== 'TRUE' {
   EDIT BLOCK XMIN UNLOCK
} ELSE {
   EDIT BLOCK XMIN LOCK
jjat-wang
thank you !!!
I always think that the state is only 0 and 1
and   widget    【ribbon.pattern.Draw.Instrument 】?
it is in ribbon ,how can i  return bool?
IF ($widget('Ribbon.Pattern.Draw.Instrument').Value == 'TRUE') {
    EDIT PATTERN ; INSTRUMENT OFF
} ELSE {
    EDIT PATTERN ; INSTRUMENT ON
Simple macro for see the appropriate commands/widget names:
MENUBARHELP DYNAMIC WIDGETNAMES
ECHO ON DCPDEBUG TRACE COMMAND ACCEPT
TOOLBAR COMMANDBAR RAISE
