Required % of cutter consumption from total tool list time
malinsAM3TM
malinsAM3TM
Hi
We are in die and mould business
We required various cutting tools to finish mould
Is there any option to get cutter consumption used in a particular power mill project
What is the total time used the particular tool used in a project as per feed given in a project
This is to analyze the cutter consumption trend
This would help to maintain cutting tool inventory
Regards
Nivrutti Mali
Godrej Tooling
ondrej.mikulec
INT LIST $toolsNumbers = extract(folder('Tool'), 'Number.Value')
INT dummy = remove_duplicates($toolsNumbers)
FOREACH $toolNumber IN toolsNumbers {
	REAL $cuttingTimeSum = 0
	FOREACH $tp IN folder("Toolpath") {
		IF $tp.Tool.Number.Value == $toolNumber {
			$cuttingTimeSum = $cuttingTimeSum + $tp.Statistics.TotalTime
	PRINT ${"Tool Number: " + $toolNumber + " Total Time: " + $time_to_string($cuttingTimeSum)}
danmic7JH66
I was playing around with this code a little and i went about it a bit differently.
Your code definitely got me on the right path but I couldn't get any values to actually output. All tools had 0.0 output simulation time for some reason. I changed it up a bit and went this route and it gave me (not the OP) the results I was hoping to get. Maybe it'll be useful for someone else. I know it could be made more efficient, I just typed it out real quick and tested.
string list tool_ = {}
foreach t in folder ('tool') {
    int add1 = add_last($tool_, $t.name )
foreach tl in $tool_ {
real tp_time = '0'
string msg = ""
    foreach tp in folder('toolpath') {
        if $tp.tool.name == $tl {
            $tp_time = $tp_time + round($tp.Statistics.TotalTime, 3)
$msg = "Tool " + $tl + " total simulation time : " + $tp_time
print $msg
malinsAM3TM
Hello Sir
I run this macro
but I am not getting time as per tool diameter
It is showing only for 1st tool and that to in seconds
It would be helpful we get output in excel
I have attached ppt and project for your reference
regards
Nivrutti Mali
