PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Reorder toolpaths inside Nc Program
5 REPLIES 5
iamcdn79
377 Views, 5 Replies
When I add multiple toolpaths with different names and different tool diameters with a macro it doesn't order the toolpaths as they were in the toolpath tree.
There is a command in the NC program to order toolpaths by tool number, tool diameter or workplane but it doesn't work. So I am trying to make a macro that reorders all the toolpaths in the active nc program by largest tool diameter, this is what I have so far but it errors on line 15 and 26
// Get the name of the active NC program
STRING ncProg = entity('ncprogram','').name
// Get the toolpaths in the active NC program
STRING LIST ncP_toolpaths = extract(entity('ncprogram', ncProg).nctoolpath, 'Name')
// Create a list to store the tool diameters
REAL LIST tool_diameters = {}
FOREACH tp IN ncP_toolpaths {
    // Get the tool entity associated with the toolpath
    ENTITY tool = entity('toolpath', tp).tool
    // Get the diameter of the tool and add it to the list
 Error on this --->   tool_diameters = append(tool_diameters, tool.diameter)
// Sort the toolpaths by tool diameter in a new list
STRING LIST sorted_toolpaths = sort(ncP_toolpaths, tool_diameters)
// Initialize a counter for the new order
INT new_order = 0
FOREACH tp IN sorted_toolpaths {
    // Reorder the toolpath in the NC program
 Will Error on this line --->   EDIT NCPROGRAM ncProg ORDER ITEM find(ncP_toolpaths, tp) AFTER ITEM new_order
    // Increment the counter
    new_order = new_order + 1
Here is the before and after if I do it manually
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
5 REPLIES 5
ondrej.mikulec
in reply to: iamcdn79
STRING LIST ncP_toolpaths_Names = extract(components(entity('ncprogram', ncProg)), 'Name')
// Get the toolpaths entities in the ncP_toolpaths_Names
ENTITY LIST ncP_toolpaths = {}
FOREACH tp IN ncP_toolpaths_Names {
    INT $i = add_last($ncP_toolpaths,entity('Toolpath',$tp))
ENTITY LIST sorted_toolpaths = sort(ncP_toolpaths, 'Tool.Diameter')
    EDIT NCPROGRAM $ncProg ORDER TOOLPATH $tp.name LAST
iamcdn79
in reply to: ondrej.mikulec
Thats better with no errors but it sorts the tool diameters by smallest first then largest when I need the largest first then smallest. Also, I need it to sort the toolpath names from smallest to largest, there would be duplicate toolpath names.
Windows 11 Pro
ondrej.mikulec
I have added the
$sorted_toolpaths = reverse(sorted_toolpaths)
and the loop
WHILE remove(ncP_toolpaths_Names,$tp.Name)
    //Do the order command till the name is present in the ncP_toolpaths_Names list
	WHILE remove(ncP_toolpaths_Names,$tp.Name) {
iamcdn79
It puts the tool diameters in the proper order but not the toolpath names, and when running the macro a second time it gives a different toolpath name order. The toolpath names needs to be from smallest to largest.
Windows 11 Pro
ondrej.mikulec
Try this:
ENTITY LIST sorted_toolpaths = sort(ncP_toolpaths, 'Name')
$sorted_toolpaths = sort(sorted_toolpaths, 'Tool.Diameter')
