PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Renumber Toolpath
11 REPLIES 11
Message 1 of 12
Pedro_Valente
378 Views, 11 Replies
Renumber Toolpath
Hello everyone,
I need a MACRO to help me renumber the toolpaths inside folder.
The macro must do is DELETE 3 frist charters, and renumber with 3 new charters I gave.
Example:
020 - dfasdfgfg
021 - asdfasdf
025 - afasdfads
026 - asdfadfa
I run MACRO, select toolpaths I want renumber. Then I gave number 200 and macro remove 020, 021, 025, 026 and renumber with 200, 201, 202, 203......... Keep the entire name of toolpah except 3 frists numbers.
I realy need re-organize toolpahs and takes me a lot of time change name one by one...
Please be kind to help me,
I already look entire forum trying to find. But nothing with 3 frists characters
I left some pictures to be like samples.
Thanks in advace for any help.
Best regards
Captura de ecrã 2024-06-11 090013.pngCaptura de ecrã 2024-06-11 090557.pngCaptura de ecrã 2024-06-11 090636.png
11 REPLIES 11
Message 2 of 12
icse
in reply to: Pedro_Valente
try this:
entity list $tps = input entity multiple toolpath 'Select Toolpaths:'
int $startNumb = input 'Start Number'
foreach $tp in $tps {
	string $newName = $startNumb + substring($tp.Name, 3)
	if entity_exists('toolpath',$newName) {
		$newName = new_entity_name('toolpath',$newName)
	rename toolpath ${tp.Name} ${newName}
	$startNumb = $startNumb + 1
at least it should give you a good starting point, im currently not able to test it becose i dont have a powermill licence atm.
Message 3 of 12
Pedro_Valente
in reply to: icse
That was an nice begin. I apreciate that. Thank you.
Now I need to limit numbers to 3 digits. I got  something here maybe that helps.
This Macro is to re-name NCPROGRAMS, just need adapt to Toolpaths and insert on your help.
If I rename toolpath with number 10, this macro put an new 0 before, completing 3 desire digits.
// Macro to renumber programs incrementing by 1 each time and adding leading zeros until field width is achieved, currently at 3 characters
Function main(){
//Variables - Variáveis
String msg = ""
Int num_length = ""
int num = 0
string snum = ""
string NC = ""
int count = 0
//Set required field width for number
//Defina a largura do campo necessária para o número
int field_width = 3
$msg = "Selecione os programas para renomear FANUC"
//$msg = "Select programs to re-number"
//Cria uma lista de todos os programas em sessão
//Create a list of all programs in session
ENTITY LIST NCP = INPUT ENTITY MULTIPLE NCProgram $msg
$msg = "Digite o primeiro numero do programa (3 Digitos)"
//$msg = "Enter first Program number"
//O número do programa não excede a largura do campo
//Check number does not exceed field_width
Do {
$num = input $msg
//Retorna o comprimento da imputação do número
//Returns length of number imput
$num_length = length($num)
If ($num_length > $field_width) {
$msg = "Numero muito longo! - Digite novamente com 4 digitos"
//$msg = "Number too long! - Re-enter"
} while ($num_length > $field_width)
//loop sobre cada programa selecionado e renumerar
//loop over each selected program and re-number
FOREACH $pg IN NCP {
	ACTIVATE NCProgram $pg.Name
	$snum = $num
	if ($num_length < $field_width) {
		//chama a função para adicionar zeros à esquerda até que a largura do campo seja alcançada
		//call function to add leading zeroes until field width is achieved
		call leading_zeroes($num, $snum, $num_length, $field_width)
	RENAME NCProgram $pg.Name $snum
	$num = $num + 1
DEACTIVATE NCProgram
STRING MacroFilePath = macro_path(false) + "\Ren_Fanuc_NC-Apoio.mac"
MACRO $MacroFilePath
//This macro puts the prefix (User input 'ProjectName') after each ncprogram name
Function leading_zeroes(int num, output string snum, int num_length, int field_width) {
//Verifica a largura do campo não mais ou menos que 3 caracteres
//Check field width not more or less than 3 characters
$snum = $num
Do {
//increment snum by adding leading zero
$snum = "0" + $snum
//incrementa snum adicionando zero à esquerda
//get lenth of $snum string
$num_length = length($snum)
} while ($num_length < $field_width)
Message 4 of 12
icse
can you test this:
	//this shoud add leading zeros if the lenght of the number is less than 3 digits
	string $prefix = substring('000', 0, 3 - length(string($startNumb))) + $startNumb
	string $newName = $prefix + substring($tp.Name, 3)
this probably gets messed up if you enter a number longer/closeto 3 digits
Message 5 of 12
Pedro_Valente
in reply to: icse
Thank You for the help.
I tryed start with only 1 and macro goes to 001. For a mess I input 998 and it make a mess. But no problem for me.
Message 6 of 12
icse
if the number goes past 999 you could reset it to 1 so you dont mess up the formating:
	if $startNumb > 999 {
		$startNumb = 1
Message 7 of 12
Pedro_Valente
in reply to: icse
Thank you one more time.
Can you please check another thing ?
If the number exist, just replace.
Sample:
100_gsgs
101_afgasfg
105_afasdf
106_asdfa
After run Macro (starting in 100):
100_gsgs_1
101_afgasfg_1
102_afasfd
103_asdfa
Macro put _1 at end because number 100 already exists. Is it possible do something about it?
Thank you
Message 8 of 12
icse
	if $tp.Name == $newName {
		continue
		$startNumb = 1
Message 9 of 12
Pedro_Valente
in reply to: icse
Not yet, if Macro found same number it just continue.
Sample:
110_qwerty
111_qwerty
111_ytrewq
111_qwertyu
120_qwerty
121_qwerty
Macro does:
110_qwerty
111_qwerty
111_ytrewq
111_qwertyu
112_qwerty
113_qwerty
Message 10 of 12
Look at screen recorder
Message 11 of 12
icse
ahh yea i forgot to increment the number before skipping... its kinda hard i cant test the macro by myselve sorry for that ^^
THX for the clip it helped a lot.
			$startNumb = 1
		continue
		$startNumb = 1
Message 12 of 12
Pedro_Valente
in reply to: icse
Step by Step this Macro grows and turns perfect for me.
Thank you very much.
With Best Regards
Technology Administrators
