rename Ncprograms macro
hrh46
hrh46
I have a macro renaming all toolpaths by an index number and tool name.is it possible to rename ncprograms based on
new toolpaths name?
icse
I think so...
But i need more information about how you whant to rename the nc program.
Can you give me an example?
hrh46
Ok. This machine has no tool change, so each nc prog even if has multiple toolpaths, use only one unique tool.
assume toolpaths:
1_EM8
4_EM10
5_EM10
one Nc has both 4_EM10 and 5_EM10, So renaming Ncs should be something like:
1_EM8
4_And_5_EM10
icse
can you try this:
entity list $ncs = input entity multiple ncprogram 'select nc programs wich should be renamed:'
if size($ncs) < 1 {
	return
foreach $nc in $ncs {
	if size(components($nc)) < 1 {
		continue
	string list $tpsuffixes = {}
	foreach $tp in components($nc) {
		int $i = add_last($tpsuffixes, tokens($tp.Name,'_')[0])
	string $newNcName = join($tpsuffixes,'_And_') + '_' + components($nc)[0].Tool.Name
	if $nc.Name == $newNcName {
		continue
	if entity_exists('ncprogram',$newNcName) {
		$newNcName = new_entity_name('ncprogram',$newNcName)
	rename ncprogram ${nc.Name} ${newNcName}
hrh46
Many Thanks. that was what I need.
