PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
rename Ncprograms macro
4 REPLIES 4
hrh46
312 Views, 4 Replies
I have a macro renaming all toolpaths by an index number and tool name.is it possible to rename ncprograms based on
new toolpaths name?
4 REPLIES 4
icse
in reply to: hrh46
I think so...
But i need more information about how you whant to rename the nc program.
Can you give me an example?
hrh46
in reply to: icse
Ok. This machine has no tool change, so each nc prog even if has multiple toolpaths, use only one unique tool.
assume toolpaths:
1_EM8
4_EM10
5_EM10
one Nc has both 4_EM10 and 5_EM10, So renaming Ncs should be something like:
1_EM8
4_And_5_EM10
icse
in reply to: hrh46
can you try this:
entity list $ncs = input entity multiple ncprogram 'select nc programs wich should be renamed:'
if size($ncs) < 1 {
	return
foreach $nc in $ncs {
	if size(components($nc)) < 1 {
		continue
	string list $tpsuffixes = {}
	foreach $tp in components($nc) {
		int $i = add_last($tpsuffixes, tokens($tp.Name,'_')[0])
	string $newNcName = join($tpsuffixes,'_And_') + '_' + components($nc)[0].Tool.Name
	if $nc.Name == $newNcName {
		continue
	if entity_exists('ncprogram',$newNcName) {
		$newNcName = new_entity_name('ncprogram',$newNcName)
	rename ncprogram ${nc.Name} ${newNcName}
hrh46
in reply to: icse
Many Thanks. that was what I need.
