Good Day,
I have this macro which will number and add toolpath info.
Once I have this, perhaps I might edit the name somewhat, replace the tool etc.
What I was wondering is if there's a way to refresh selected toolpaths, keeping the toolpath number but refreshing the tool info?
IF $powermill.Status.MultipleSelection.First OR $powermill.Status.MultipleSelection.Total == 0 { reset localvars string $new_name = "" STRING Strategy = 'null' DIALOGS MESSAGE OFF DIALOGS ERROR OFF GRAPHICS LOCK //starting number INT StartNumber = INPUT "Start at #?" INT start = $StartNumber STRING start1 = $StartNumber INT i = $start1 //set text to replace and new text STRING oldText = "." STRING newText = "," // IF { // Commands A // } ELSEIF { // Commands B // } ELSE { // Commands C // } FOREACH $tp IN explorer_selected_entities() { IF tp.drill.type == "helical" { //RENAME TOOLPATH $tp.Name ${i + "_" + tp.Strategy + "_" + tp.drill.type + "_" + tp.Tool.Identifier + "_T" + tp.tool.number} RENAME TOOLPATH $tp.Name ${i + "_" + tp.Strategy + "_" + tp.drill.type + "_" + tp.Tool.Identifier + "_XY" + tp.Drill.Thickness + "_Z" + tp.Drill.AxialThickness + "_T" + tp.tool.number} $i = $i + 1 } ELSEIF tp.drill.type == "thread_mill" { RENAME TOOLPATH $tp.Name ${i + "_" + tp.Strategy + "_" + tp.drill.type + "_" + tp.Tool.Identifier + "_XY" + tp.Drill.Thickness + "_T" + tp.tool.number} $i = $i + 1 } ELSEIF $tp.Strategy == "drill" { RENAME TOOLPATH $tp.Name ${i + "_" + tp.Strategy + "_" + tp.drill.type + "_" + tp.Tool.Identifier + "_T" + tp.tool.number} $i = $i + 1 } ELSEIF tp.drill.type == "deep_drill" { RENAME TOOLPATH $tp.Name ${i + "_" + tp.Strategy + "_" + tp.drill.type + "_" + tp.Tool.Identifier + "_T" + tp.tool.number} $i = $i + 1 } ELSEIF tp.drill.type == "break_chip" { RENAME TOOLPATH $tp.Name ${i + "_" + tp.Strategy + "_" + tp.drill.type + "_" + tp.Tool.Identifier + "_T" + tp.tool.number} $i = $i + 1 } ELSEIF $tp.Strategy == "swarf" { RENAME TOOLPATH $tp.Name ${i + "_" + tp.Strategy + "_" + tp.Tool.Identifier + "_XY" + tp.Thickness + "_Z" + tp.axial_thickness + "_T" + tp.tool.number} $i = $i + 1 } ELSEIF $tp.Strategy == "surface_machine" { RENAME TOOLPATH $tp.Name ${i + "_" + tp.Strategy + "_" + tp.Tool.Identifier + "_XY" + tp.Thickness + "_Z" + tp.axial_thickness + "_T" + tp.tool.number} $i = $i + 1 } ELSEIF $tp.Strategy == "curve_profile" { RENAME TOOLPATH $tp.Name ${i + "_" + tp.Strategy + "_" + tp.Tool.Identifier + "_XY" + tp.CurveThickness + "_T" + tp.tool.number} $i = $i + 1 } ELSEIF $tp.Strategy == "chamfer" { RENAME TOOLPATH $tp.Name ${i + "_" + tp.Strategy + "_" + tp.Tool.Identifier + "_XY" + tp.CurveThickness + "_T" + tp.tool.number} $i = $i + 1 } ELSEIF $tp.Strategy == "curve_area_clear" { RENAME TOOLPATH $tp.Name ${i + "_" + tp.Strategy + "_" + tp.Tool.Identifier + "_XY" + tp.CurveThickness + "_T" + tp.tool.number} $i = $i + 1 } ELSE { RENAME TOOLPATH $tp.Name ${i + "_" + tp.Strategy + "_" + tp.Tool.Identifier + "_XY" + tp.Thickness + "_Z" + tp.axial_thickness + "_T" + tp.tool.number} $i = $i + 1 } IF position(tp.name, oldText) >= 0 { STRING newName = replace(tp.name, oldText, newText) RENAME TOOLPATH $tp.name $newName STRING newName2 = replace(tp.name, "chamfer", "Chamf") RENAME TOOLPATH $tp.name $newName2 STRING newName3 = replace(tp.name, "curve_profile", "Crv-Prof") RENAME TOOLPATH $tp.name $newName3 STRING newName4 = replace(tp.name, "adaptive_area_clear", "Vort-AreaClear") RENAME TOOLPATH $tp.name $newName4 STRING newName5 = replace(tp.name, "surface_machine", "SurfMachine") RENAME TOOLPATH $tp.name $newName5 STRING newName6 = replace(tp.name, "offset_area_clear", "Off-AreaClear") RENAME TOOLPATH $tp.name $newName6 STRING newName7 = replace(tp.name, "drill", "Drill") RENAME TOOLPATH $tp.name $newName7 STRING newName8 = replace(tp.name, "swarf", "Swarf") RENAME TOOLPATH $tp.name $newName8 STRING newName9 = replace(tp.name, "pattern", "Pattern") RENAME TOOLPATH $tp.name $newName9 STRING newName10 = replace(tp.name, "curve_area_clear", "Crv-AreaClear") RENAME TOOLPATH $tp.name $newName10 STRING newName11 = replace(tp.name, "face", "Face") RENAME TOOLPATH $tp.name $newName11 STRING newName12 = replace(tp.name, "embedded", "Embed") RENAME TOOLPATH $tp.name $newName12 STRING newName13 = replace(tp.name, "offset_flat", "Off-Flat") RENAME TOOLPATH $tp.name $newName13 STRING newName14 = replace(tp.name, "offset_3d", "Off-3d") RENAME TOOLPATH $tp.name $newName14 STRING newName15 = replace(tp.name, "constantz", "Const-Z") RENAME TOOLPATH $tp.name $newName15 STRING newName16 = replace(tp.name, "automatic_corner", "AutoCorn") RENAME TOOLPATH $tp.name $newName16 STRING newName17 = replace(tp.name, "multi_pencil_corner", "MultiPen") RENAME TOOLPATH $tp.name $newName17 STRING newName18 = replace(tp.name, "pencil_corner", "Pencil") RENAME TOOLPATH $tp.name $newName18 STRING newName19 = replace(tp.name, "disc_profile", "DiscProf") RENAME TOOLPATH $tp.name $newName19 STRING newName20 = replace(tp.name, "flowline", "Flow") RENAME TOOLPATH $tp.name $newName20 STRING newName21 = replace(tp.name, "opti_constz", "OptiConstZ") RENAME TOOLPATH $tp.name $newName21 STRING newName22 = replace(tp.name, "parametric_offset", "ParaOffset") RENAME TOOLPATH $tp.name $newName22 STRING newName23 = replace(tp.name, "parametric_spiral", "ParaSpiral") RENAME TOOLPATH $tp.name $newName23 STRING newName24 = replace(tp.name, "profile", "Prof") RENAME TOOLPATH $tp.name $newName24 STRING newName25 = replace(tp.name, "curve_projection", "Crv-Proj") RENAME TOOLPATH $tp.name $newName25 STRING newName26 = replace(tp.name, "line_projection", "LineProj") RENAME TOOLPATH $tp.name $newName26 STRING newName27 = replace(tp.name, "plane_projection", "PlaneProj") RENAME TOOLPATH $tp.name $newName27 STRING newName28 = replace(tp.name, "point_projection", "PointProj") RENAME TOOLPATH $tp.name $newName28 STRING newName29 = replace(tp.name, "surFace_proj", "Surf-Proj") RENAME TOOLPATH $tp.name $newName29 STRING newName30 = replace(tp.name, "radial", "Radial") RENAME TOOLPATH $tp.name $newName30 STRING newName31 = replace(tp.name, "raster", "Raster") RENAME TOOLPATH $tp.name $newName31 STRING newName32 = replace(tp.name, "Raster_flat", "Rast-Flat") RENAME TOOLPATH $tp.name $newName32 STRING newName33 = replace(tp.name, "rest_finishing", "RestFinish") RENAME TOOLPATH $tp.name $newName33 STRING newName34 = replace(tp.name, "rotary", "Rotary") RENAME TOOLPATH $tp.name $newName34 STRING newName35 = replace(tp.name, "spiral", "Spiral") RENAME TOOLPATH $tp.name $newName35 STRING newName36 = replace(tp.name, "inter_constz", "SteepShallow") RENAME TOOLPATH $tp.name $newName36 STRING newName37 = replace(tp.name, "wireframe_Profile", "WireProf") RENAME TOOLPATH $tp.name $newName37 STRING newName38 = replace(tp.name, "wireframe_Swarf", "WireSwarf") RENAME TOOLPATH $tp.name $newName38 STRING newName39 = replace(tp.name, "bore_1", "Ream") RENAME TOOLPATH $tp.name $newName39 STRING newName40 = replace(tp.name, "tap_2", "RigidTap") RENAME TOOLPATH $tp.name $newName40 STRING newName41 = replace(tp.name, "single_peck", "Sing-Peck") RENAME TOOLPATH $tp.name $newName41 STRING newName42 = replace(tp.name, "helical", "Heli") RENAME TOOLPATH $tp.name $newName42 STRING newName43 = replace(tp.name, "break_chip", "Universal") RENAME TOOLPATH $tp.name $newName43 STRING newName44 = replace(tp.name, "deep_Drill", "DeepDrill") RENAME TOOLPATH $tp.name $newName44 STRING newName45 = replace(tp.name, "Raster_area_clear", "Rast-AreaClear") RENAME TOOLPATH $tp.name $newName45 STRING newName46 = replace(tp.name, "corner_clear", "CornerClear") RENAME TOOLPATH $tp.name $newName46 STRING newName47 = replace(tp.name, "Profile_area_clear", "ProfAreaClear") RENAME TOOLPATH $tp.name $newName47 STRING newName48 = replace(tp.name, "plunge", "Plunge") RENAME TOOLPATH $tp.name $newName48 STRING newName49 = replace(tp.name, "Drill_thread_mill", "ThreadMill") RENAME TOOLPATH $tp.name $newName49 STRING newName50 = replace(tp.name, "port_area_clear", "PortAreaClear") RENAME TOOLPATH $tp.name $newName50 STRING newName51 = replace(tp.name, "port_Plunge", "PortPlunge") RENAME TOOLPATH $tp.name $newName51 STRING newName52 = replace(tp.name, "port_Spiral", "PortSpiral") RENAME TOOLPATH $tp.name $newName52 STRING newName53 = replace(tp.name, "surFace_inspection", "Probing") RENAME TOOLPATH $tp.name $newName53 DEACTIVATE Toolpath DEACTIVATE TOOL UNDRAW TOOL ALL } } DIALOGS MESSAGE ON DIALOGS ERROR ON GRAPHICS UNLOCK
