Programming Lathe Work in Powermill
I'm starting to do some investigation about programming a lathe with Y axis tooling.
For the sake of exploration I am going to pretend that the prefered lathe is going to be a HAAS ST-30
Do you program for your lathe in Powermill? If so how is it treating you.
How was post-configuration/general setup?
How is the crash detection/simulation?
If you're using live tooling, in what context?
Are you doing sub-spindle transfer style machining? Robot intergration?
My understanding is that the lathe-specific paths are all based on features;  How has that worked out?
I figured I'd reach out to the community to see who has some experience integrating this in PowerMill rather than using a feature-cam add on or other additional software.
dans4DQYP
I have programming our Haas st-20 for about 1 1/2 - 2years now    Its goin alright   The only thing is we program threads at the controller      otherwise all is done in Powermill      I wrote my own post .     Powermill is very basic for
turning .    But it works ok  for us   I am hoping Autodesk will expand on Powermill capabilities.   We donot have
Y axis on our lathe .   Collision checking and simulation  could use some help .     Yep you need to create features.
I have created a number of enhancement cases to Autodesk    Have not heard back on any of them.
The last Rev Powermill added Pattern turning which helped.   I don't believe
that  there are many Powermill Users using the turning portion. so support from others users is limited .
Good luck
From asking around that seems to be the case.
I don't think the Y axis style tools are supported at all so that's unfortunate but good to know anyway.
I may have to look more at mill-turn style machines which doesn't really break my heart as much as my wallet.
Michaelangelo631
I have also used powermill to program my 2 axis Okuma Lathe.  The majority of the programming is done at the control using the okuma conversational programming package.  However there are certain times where I need a very custom approach and powermill has served me well in this regard.  Having these features in powermill has been very useful and I am glad they continue to develop them further.  We are also getting into 5 axis now and will eventually look into applying the turn toolpaths on that machine as well.
