PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Powermill Surface triangle tolerance
3 REPLIES 3
hilling
726 Views, 3 Replies
I import Inventor parts in Powermill. Export to igs, import to Powermill. But the triangles are not so fine as i want.
If i import the same file in Autodesk Manufacturing Data Echange utility, i van change the the paramter Triangulationstoleranz to 0,001 and it looks fine. Is there a parameter in Powermill to set this paremeter to?
Labels (2)
3 REPLIES 3
Craig.Burney_DSI
in reply to: hilling
@hilling  Check and see what your Shading Tolerance is set to in your "Model Drawing Options".  If you tighten that tolerance up the model should look much better.  See the screen grab below.
Craig Burney
Senior Application Engineer
Design & Software International
hilling
in reply to: Craig.Burney_DSI
super,
Thanks for your fast help...
Hubert
Craig.Burney_DSI
@hilling   Awesome, not a problem.  Glad it worked for you!
Craig Burney
Technology Administrators
