PowerMill [Setup sheet] [MinZ Value]
armin.bosnjakN3JE3
armin.bosnjakN3JE3
Good morning community,
I have one issue with modifying SetupSheet files (.html Summary file).
I am trying to make solution which suits us best. I already create solution but I am having issue with parameter regarding MinZ value for toolpath which would help operator to know how deep tool is going.
Currently situation is next:
As You can see, field is totally blank, is this common issue or ?
PS Does toolpath has to be limited using Limit tab or no ?
EDIT: I tried limiting toolpath but output has same issue.
Thanks a lot.
nguyenthinhvt95
Try this code bro:
{TPZMin}
armin.bosnjakN3JE3
Thanks a lot bro @nguyenthinhvt95 , I accepted solution.
Is it possible to share that document here ? Cause I have something similar but much shorter.
EDIT: Find the document locally on computer, thanks.
nguyenthinhvt95
@armin.bosnjakN3JE3 : Here you go.
You can extract and open this file in Excel.
It contains all code for your setup sheet
armin.bosnjakN3JE3
Thanks a lot for help. 👊
