Powermill Import Vise Plugin
baylortech
Message 1 of 24
baylortech
Just viewed the "What's New in PowerMill for Aerospace 2018" webinar and the presenter uses a plugin for loading a vise.
Does anyone know where/how to get the plugin?
Look like it comes with FeatureCAM but I don't see anything for Powermill.
Replies (23)
Message 2 of 24
jitendra.chaudhari
Hi @baylortech,
Thanks for contacting Autodesk Community Forum..
Currently there is no Vise Import Plugin for PowerMill. I am raising a change request to PowerMill development team for this feature request.
I will keep you updated for major updates in this change request you can ask through this forum thread.
Thank  you for your time and co-operation,
Jitendra Chaudhari.
Message 3 of 24
dames99
If you already have FeatureCAM installed, just create a macro in PowerMILL to run the executable in the Addins folder of the FeatureCAM install. If you don't have FeatureCAM I'm sure someone at Autodesk can send you the files.
Message 4 of 24
baylortech
Can you provide an example of running an exe file from a Macro?
Message 5 of 24
dames99
Sure. You will need to change the path but this is the code:
 OLE FILEACTION "OPEN" "M:\Programming\DelCam\PMILL CUSTOM\Vice Import\Import_Vise.exe"
Message 6 of 24
baylortech
Thank you!
Where is "OLE FILEACTION" documented?
Message 7 of 24
bartmann_in_MN
You can do it by using "IMPORT MODEL" command in a macro instead of a .exe if you wish.
For example, save a .mac file with this code:
IMPORT MODEL "C:\delcam_data\Company_Macros\Import_Fixture\models\Nice_vise.dgk"
Then, call the macro from your user menu:
M "Import Fixture......"
I "Nice Vise" 1 "Macro Import_Nice_vise"
Alternatively, I think you could do it without a macro and just issue the command directly from the user menu.
I haven't updated to 2018 yet but here's what I have in 2017:
2017-06-14 11_46_31-Autodesk PowerMill Premium 2017    [ Editable Project _ M1874-600 ].png
Message 8 of 24
dames99
He's trying to use this addin from FeatureCAM. It gives you many choices for work holding and places the vice correctly on the part automatically. It's really very well done.
Message 9 of 24
bartmann_in_MN
Cool Man Surprised
Message 10 of 24
lopezerik73
Can you provide an example of running an exe file from a Macro too?
Many thanks in advance.
Kindly regards.
Message 11 of 24
baylortech
"dames99" posted this earlier (see above)
Message 12 of 24
iamcdn79
The only downside about this nice addin is that it only works for the first powermill window opened
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 13 of 24
dames99
Yes, that is one limitation. Also, you can't add additional vices to the library. I think there is a wish for that already logged with Autodesk though. Keep in mind that this addin was designed for FeatureCAM and it does work in multiple windows on that software.
Message 14 of 24
baylortech
Michael Grenier (webinar presenter) posted the files:
https://autodesk.app.box.com/s/kyrxenkost5htnmufeei3yi8dj1k6yyh
Message 15 of 24
Thanks !
But, for PowerMILL it work very bad -
Part, Vices and parallels are in very different positions
Message 16 of 24
Does it also do that if its made as a plugin ?
Message 17 of 24
briannystadvej
Hi
Very nice job. Is there any chance to get the source file for that project. Have some ideas for it. 🙂
Message 18 of 24
gosmann.andreas
something new on this?
can someone provide the newest plugin what can be used in PowerMill?
Message 19 of 24
glen_h
I too find this would be useful. Could someone post where to get the exe or plugin please and thank you.
I clicked on the link for files posted by Grenier as described in a previous post in this thread, however those files are no longer available.
Would like to try this out, thanks in advance.
Big thanks to all who contribute!
My opinions are my own and are not intended to reflect yours.
Message 20 of 24
omartiz
Good afternoon everybody in the forum,
Someone could upload again the files for the Import Vise plugins?
Any update regarding the Pmill usability?
Regards
