PowerMill API - 'EntityCreated' event not fired if NC program item created
iroda
iroda
Hi All,
Anyone faced the issue that PowerMill's event manager doesn't fire 'EntityCreated' event if an NC program item created?
I've subscribed to 'EntityCreated' event, and the event fired for all types of PowerMill entities (toolpaths, patterns, etc.) but NC program items. Any idea?
Thx.
dsmits
if i had to guess its only for these
print = to_xml(valid_entity_types())
Process Command : [print = to_xml(valid_entity_types())\r]
<array>
<string>MachineTool</string>
<string>NCProgram</string>
<string>Setup</string>
<string>Toolpath</string>
<string>Tool</string>
<string>Boundary</string>
<string>Pattern</string>
<string>FeatureGroup</string>
<string>Featureset</string>
<string>Workplane</string>
<string>Level</string>
<string>Model</string>
<string>StockModel</string>
<string>Group</string>
<string>Macro</string>
<string>Process</string>
<string>DrillingHole</string>
</array>
dsmits
there is an event for
<NCProgramItemAdded event_group="NCProgram">
<InsertedItemName/>
<InsertedItemType/>
<Name/>
</NCProgramItemAdded>
<NCProgramItemRemoved event_group="NCProgram">
<Name/>
<RemovedItemName/>
<RemovedItemType/>
</NCProgramItemRemoved>
iroda
The list seems to me correct. Although, I don't really understand how does your post answer my question...
Anyway, in this example (line 111) on GitHub the NC program entity type is called 'Ncprogram' (note the lowercase characters) instead of 'NCProgram' as in your array: powermill-api-examples
iroda
Yeah, I'm aware of those NCProgram related events. However, these events fired only if I add/remove a toolpath to/from an NC program - which suggest that the API has a different interpretation of an 'NC program item' as myself. In my interpretation an NC program item is the NC program itself, and not its toolpath child elements...
dsmits
mmm not sure
i use powermill plugin and works. i dont use the api
        Public Sub ProcessEvent(ByVal EventData As String) Implements PowerMILL.IPowerMILLPlugin.ProcessEvent
            Try
                Dim xe As XElement = XElement.Parse(EventData)
                If xe Is Nothing Then Exit Sub
                If xe.Name.LocalName.Equals("EntityCreated") Then
                    MsgBox(EventData.ToString)
            Catch ex As Exception
            End Try
        End Sub
iroda
My bad. I've found the problem. It is very recommended not to declare a list only, but also initialize it... and not in a deep function somewhere in a code which you think is executed, but actually executed too.
BTW, you are using the API, if your plugin works. The plugin is using it 🙂
Thx. for the help and your time.
