Hello @Anonymous , @jdh3685
Imagine that in your PowerMill additive session you have defined some recipe like these :
mz
Or another one like that
You should note that there is a recipe name, and an output tag.
As you can see with spot size, it could be written differently.
The recipe name is only used in the PowerMill session.
The output tag will be the important thing for later.
Then you are using these recipes in your toolpath.
You have so far achieved these steps.
Now, how can we used these things inside Autodesk Manufacturing Post Processor Utility ?
Launch AMPPU, open your post, switch to the editor tab.
Then in the editor tab, switch to the parameter panel.
Via a right click, create a new user parameter.
By default, you should choose a Standard Parameter, but then had to select the type.
Depending on the format of the data, you can either choose a string, or a real number. (for an integer, just play with the formatting of the value)
What will be important, both in the PowerMill session, and in the post processor, is to respect the parameter / Output tag characters case.
For example, the Select_Bol_1, or the SPOT_SIZE, in the PowerMill session will become udp_Select_Bol_1 and udp_SPOT_SIZE in AMPPU.
So case should be respected, and udp_ must be added to the PowerMill output tag name.
I hope my explanations are clear enough.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
