PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
PowerMill 2025
37 REPLIES 37
Message 1 of 38
lawrence.halls83P7Q
4729 Views, 37 Replies
PowerMill 2025
PowerMill 2025 and the PowerMill 2025.0.1 Hot Fix were released today. Over the next few weeks, you will see PowerMill 2025 and PowerMill 2025.0.1 Hot Fix availability in your account. Please check your Autodesk Account or Autodesk Access to see when your entitlement is available for download.
When you install PowerMill 2025, the PowerMill 2025.0.1 Hot Fix should automatically install with it. Alternatively, you can download the PowerMill 2025.0.1 Hot Fix from the Product Updates area of your Autodesk Account. To confirm that you've successfully installed the PowerMill 2025.0.1 Hot Fix, select the  ?  > About  menu option in your PowerMill 2025 software and check that you're working in Version: 2025.0.1.2025012.
In the meantime, you can review the Help and Release Notes to see what is being delivered in PowerMill 2025 and the PowerMill 2025.0.1 Hot Fix.
Thank you
Lawrence Halls
QA Engineer
37 REPLIES 37
Message 21 of 38
evo80
in reply to: Sean571
Only Toolpaths though Sean
Message 22 of 38
nguyenthinhvt95
@Sean571 You are right, we can use Group to export multiple toolpaths.
Message 23 of 38
evo80
in reply to: icse
Hi @icse,
I'd like to add models to the Export macro but I get an error at line 146, could you help?
Appreciated!
if length(project_pathname(0)) == 0 OR project_modified() == 1 {
	message warn 'Save First'
	return
string $path = "C:/Temp/EntityExport"
if dir_exists($path) {
	bool $query = 0
	$query = query "Replace existing Entities?"
	if $query {
		delete directory $path
	} else {
		return
string list $inputTypes = {'toolpath','tool','boundary','pattern','featureset','workplane','model'}
int list $indexer = input choice multiple $inputTypes 'Choose Type of Entity to Export'
entity list $entitiesToExport = {}
foreach $index in $indexer {
	entity list $entities = {}
	SWITCH $index {
		Case 0
			$entities = input entity multiple toolpath 'Select Toolpaths to Export'
			Break
		Case 1
			$entities = input entity multiple tool 'Select Tools to Export'
			Break
		Case 2
			$entities = input entity multiple boundary 'Select Boundaries to Export'
			Break
		Case 3
			$entities = input entity multiple pattern 'Select Patterns to Export'
			Break
		Case 4
			$entities = input entity multiple featureset 'Select Featuresets to Export'
			Break
		Case 5
			$entities = input entity multiple workplane 'Select Workplanes to Export'
			Break
		Case 6
			$entities = input entity multiple model 'Select Models to Export'
			Break
		DEFAULT
			return
			BREAK
	foreach $ent in $entities {
		int $i = add_last($entitiesToExport, $ent)
mkdir $path
//Active entity file
string $activeEntityFilePath = $path + '/active_entity.pmldat'
string $op = '0 1 # Active Entities (DO NOT EDIT!)'
if file_exists($activeEntityFilePath) {
	delete File $activeEntityFilePath
file open $activeEntityFilePath for write as output
file write $op to output
file close output
int $entCount = 0
string $content = ''
foreach $e in $entitiesToExport {
	if entity_exists($e) {
		if $e.RootType == 'toolpath' {
			string $eHash = "x" + $e.ID + ".pmlent"
			string $e_full = project_pathname(0) + "/" + $eHash
			string $path_full = $path + "/" + $eHash
			if not file_exists($path_full) {
				$entCount = $entCount + 1
				$content = $content + $eHash + " pmlEntToolpath '" + $e.Name + "'" + CRLF
			copy file $e_full $path_full
			$eHash = "x" + $e.ID + ".pmlgeom"
			if entity_exists($e.Boundary) {
				$eHash = "x" + $e.Boundary.ID + ".pmlent"
					$content = $content + $eHash + " pmlEntBoundary '" + $e.Boundary.Name + "'" + CRLF
			if entity_exists($e.Pattern) {
				$eHash = "x" + $e.Pattern.ID + ".pmlent"
					$content = $content + $eHash + " pmlEntPattern '" + $e.Pattern.Name + "'" + CRLF
			if entity_exists($e.Tool) {
				$eHash = "x" + $e.Tool.ID + ".pmlent"
					$content = $content + $eHash + " pmlEntTool '" + $e.Tool.Name + "'" + CRLF
			if entity_exists($e.Workplane) {
				$eHash = "x" + $e.Workplane.ID + ".pmlent"
					$content = $content + $eHash + " pmlEntWorkplane '" + $e.Workplane.Name + "'" + CRLF
			if entity_exists($e.Featureset) {
				$eHash = "x" + $e.Featureset.ID + ".pmlent"
					$content = $content + $eHash + " pmlEntFeature '" + $e.Featureset.Name + "'" + CRLF
			if entity_exists($e.Model) {
				$eHash = "x" + $e.Model.ID + ".pmlent"
					$content = $content + $eHash + " pmlEntModel '" + $e.Model.Name + "'" + CRLF
			continue
		if $e.RootType == 'boundary' {
			string $eHash = "x" + $e.Boundary.ID + ".pmlent"
				$content = $content + $eHash + " pmlEntBoundary '" + $e.Name + "'" + CRLF
			continue
		if $e.RootType == 'pattern' {
			string $eHash = "x" + $e.Pattern.ID + ".pmlent"
				$content = $content + $eHash + " pmlEntPattern '" + $e.Name + "'" + CRLF
			continue
		if $e.RootType == 'tool' {
			string $eHash = "x" + $e.Tool.ID + ".pmlent"
				$content = $content + $eHash + " pmlEntTool '" + $e.Name + "'" + CRLF
			continue
		if $e.RootType == 'workplane' {
			string $eHash = "x" + $e.Workplane.ID + ".pmlent"
				$content = $content + $eHash + " pmlEntWorkplane '" + $e.Name + "'" + CRLF
			continue
		if $e.RootType == 'featureset' {
			string $eHash = "x" + $e.Featureset.ID + ".pmlent"
				$content = $content + $eHash + " pmlEntFeature '" + $e.Name + "'" + CRLF
			continue
		if $e.RootType == 'model' {
			string $eHash = "x" + $e.model.ID + ".pmlent"
				$content = $content + $eHash + " pmlEntModel '" + $e.Name + "'" + CRLF
			continue
file close output
string $proj_name = "\" + project_pathname(1) + ".pmlprj"
string $path_full = project_pathname(0) + $proj_name
file open $path_full for read as input
string $line1 = ''
string $line2 = ''
string $line3 = ''
file read $line1 from input
file read $line2 from input
file read $line3 from input
file close input
$line1 = $entCount + substring($line1, position($line1, ' ', 0), length($line1))
string $dest_path_full = $path + $proj_name
file open $dest_path_full FOR WRITE AS output
file write $line1 to "output"
file write $line2 to "output"
file write $line3 to "output"
file write $content to "output"
file close output
Message 24 of 38
icse
in reply to: evo80
You got one } to much and i think you also need to copy .pmlmz file:
	return
	bool $query = 0
	if $query {
	} else {
		return
	SWITCH $index {
		Case 0
			Break
		Case 1
			Break
		Case 2
			Break
		Case 3
			Break
		Case 4
			Break
		Case 5
			Break
		Case 6
			Break
		DEFAULT
			return
			BREAK
mkdir $path
file close output
int $entCount = 0
			continue
			continue
			continue
			continue
			continue
			continue
			$eHash = "x" + $e.model.ID + ".pmlmz"
			continue
file close output
string $line1 = ''
string $line2 = ''
string $line3 = ''
file close input
file close output
We probably should open a new post insted of spamming here 😛
Message 25 of 38
iamcdn79
in reply to: ken.poyner
I've noticed a bug when pasting a toolpath and renumbering the pasted toolpath Powermill seems to reorder single-character toolpath names from the toolpath list.
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 26 of 38
icse
Is it possible to remove the logo when you start Powermill?
It blocks half of the screen...
Message 27 of 38
rafael.sansao
in reply to: icse
Message 28 of 38
Hi Guys, Could we please get a solution to display the tool numbers in the tools folder, (so if I set the tool to Tool 2, perhaps automatically add a #2 before the Tool name?)
We are a job shop that is for ever changing jobs and tools. trying to remember what tools are set/empty can be a serious headache.
hope its possible to add into an update sometime.
(automatically add after the tool symbol)
(Active tool : #2 > EM-3.0-SC)
Message 29 of 38
Beta_Librae
in reply to: nathanANTQX
I've added the active tool number as an expression in the quick access toolbar. Not exactly what you're looking for, but I find it pretty helpful.
Kind Regards,
Not cnc, you can call me Peabrain
Message 30 of 38
nathanANTQX
in reply to: Beta_Librae
That is an excellent idea, perhaps suited to something else for us. It gets a bit annoying to try and slot a new tool into the tool carousel, sometimes we run into a tough situation because our machines have 21 tools. sometimes we are able to modify our approach to fit the number of tools in the machine. but trying to remember where you have set those tools to find the last 3 open spots can become laborious. (post out to find tool number collision -> update the tool number, clashes with the next tool etc)
If the information could be displayed in the tool icon are as a default, without updating the tool name. it could be a visible cue to the programmers to try and slot the tools into the carousel.
I hope that gives a little more clarity.
Message 31 of 38
icse
this macro pops up a message box with the first free tool number:
int list $toolnumblist = extract(folder('TOOL'), 'Tool.Number.Value')
int $newToolNumb = 1
while member( $toolnumblist, $newToolNumb) {
	$newToolNumb = $newToolNumb + 1
Message Info $newToolNumb
this macro shows you all tools with duplicate numbers:
int list $toolnumbers = extract(folder('tool'),'Number.Value')
int $i = remove_duplicates($toolnumbers)
string $op = ''
foreach $n in $toolnumbers {
	string list $names = extract(filter(folder('tool'),'this.Number.Value == "' + $n + '"'),'Name')
	if size($names) > 1 {
		$op = $op + 'T ' + $n + CRLF
		foreach $name in $names {
			$op = $op + $name + CRLF
		$op = $op + CRLF
message info $op
Message 32 of 38
Beta_Librae
I got ya now. You're looking for the tools that aren't there.
Kind Regards,
Message 33 of 38
evo80
in reply to: icse
@icse
What would be really handy is a variation on this that will return the unused tool numbers from a compliment of say 60 tools?
Best Regards
Message 34 of 38
icse
in reply to: evo80
You could automatically give the active tool if that tool does not have a number the first free tool number.
to show a list of all free tool numbers from 1 to 60 you could use something like this:
int $numb = 1
int list $freeNumbs = {}
string $op = ''
while $numb <= 60 {
	if not member( $toolnumblist, $numb) {
		int $i = add_last($freeNumbs,$numb)
		$op = $op + $numb + CRLF
	$numb = $numb + 1
Message Info $op
Message 35 of 38
evo80
in reply to: icse
@icse,
That's perfect!
Cheers!!
Message 36 of 38
Regarding the drawing of the stock in Setups in the release notes, how does this work? When turning it off and deactivating the setup but then re-activating it, it just draws again every time. I was hoping it would keep it undrawn every time.
And how is this any different from older versions? 2023 has the same options
Windows 11 Pro
Message 37 of 38
Sorry. Problem is in powershape 2025.
Message 38 of 38
Have you raised CERs? Can you send me your email in a DM so I track them down.
Do you have a project and/or some reproduction instructions you could send to me too so I can try and reproduce the issue?
Ken Poyner
Software Engineer (PowerMill)
Technology Administrators
