PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
PowerMill 2021 very slow
6 REPLIES 6
support
1286 Views, 6 Replies
I am currently trying to resolve an issue for a user. Their software seems to be running very slow, to the point where it is almost unusable. I have made sure the latest patch has been installed. I have also tested a number of designs, each time one is loaded it causes the issue. The only recent change is that I have since connected a new tooldata base.
The machine itself is more then capable of running the software. Any other ideas what could be causing the issue?
Tags (1)
Labels (2)
6 REPLIES 6
TK.421
in reply to: support
What in particular runs slow? The software as a whole, or are there specific operations that are slow? What are the specs of the machine that it's running?
I program a wide range of things that vary from the size of a chair seat to the size of an RV and I dont have any issues (other than the form loading time that has gotten progressively longer the past few years).
the numbers never lie
support
in reply to: TK.421
The programme seems to run extremely slow to the point of no use when a design has been loaded.
The PC being used is a Dell precision Tower:
Motherboard: Dell Inc. 08K0X7 Processor: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz Physical Cores: 4 Memory: 15.9 GB Display Adapter: Intel(R) HD Graphics 530
Could the graphics card need an upgrade?
TK.421
I think the whole computer needs an upgrade, but the gpu at minimum. Here’s a comparison between what you and I run for gpu. I also run intel Xeon and 32gb memory.
im sorry, but this machine seems too outdated for pmill 2021.
support
in reply to: TK.421
That's good to know, Thanks for your help!
Sean570
Here are the minimum requirements to run powermill 2021
https://knowledge.autodesk.com/support/powermill/learn-explore/caas/sfdcarticles/sfdcarticles/System...
You need a much better graphics card
I have an Invidia Quadro K2200 and that works fine for most things, though not for larger models.
Craig.Burney_DSI
@support  I would say that the biggest contributor to the slow down is the Intel graphics card.  The graphics card that comes with the computer is never good enough for CAD/CAM application.  Autodesk recommends a NVIDIA Quadro card because that is the brand they do all of their testing with.  I hope this helps.
Craig Burney
Senior Application Engineer
Design & Software International
Technology Administrators
