Powermill 2020 crashing while calculating toolpaths
I've been having a persistent issue with my PowerMill, where it crashed while calculating mostly corner finishing toolpaths.
A 'SERIALNUM' error appears and a feedback to Autodesk is required so be sent.
I had this happening while changing the starting point of a toolpath.
I suspect it might be calculating links that creates the issue.
cfastNJWK6
What version of 2020 are you running?  I beleive this is a problem that was fixed in the  2020.2.2 update.
It might be something as simple as that. I stopped using PowerMill for a while. I don't have any version update notification, but I'll still download 2.2 version.
Jonathan_Artiss19
Check if there are updates to your graphics driver as well, this can sometimes cause crashes if out of date.
Jonathan Artiss
Senior Applications Engineer | DSI
Autodesk Expert Elite member
DSI, Design and Software International Autodesk Gold Partner
