PowerMill Forum
Welcome to Autodeskā€™s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Showing results forĀ
Did you mean:Ā
PowerMill 2018......what would YOU like to see?
115 REPLIES 115
Message 1 of 116
clinton.perry
5157 Views, 115 Replies
We're working on the next release of PowerMill and would love to hear from our active forum community (that's you guys BTW).
What would like to see in the next version and why?
115 REPLIES 115
Message 61 of 116
M_Hennig
I would say under stock engagement depth of cut, set the maximum..
Mike Hennig
5axis programming specialist
Please visit us at:
[cid:image001.png@01D28212.F4BC0270]
Rosemont IL (June 14-15th)
Booth# 917
[omega logo]
Omega Tool, Inc.
N93 W14430 Whittaker Way
Menomonee Falls, WI 53051
262-255-0205
262-255-3964 fax
Message 62 of 116
zfreitas
in reply to: zfreitas
Check the attached project (mm)
Cumprimentos,
JOSƉ CARLOS FREITAS
DIRECTOR TƉCNICO - ENG. - 935576133
[LOGO-ORIGINAL-010310]
NORCAM - ENGENHARIA E DESIGN INDUSTRIAL, LDA - RUA DE SALAZARES 842 - 4149-002 PORTO, PORTUGAL
TEL: +351 225322000 - FAX: +351 226177662 - WWW.NORCAM.PT - norcam@norcam.pt
Best regards,
Jose Carlos Freitas
Tech Support Engineer
NORCAM
Message 63 of 116
cory_marty
in reply to: clinton.perry
-Ability to undo accidentally deleting of model components when thinking you were deleting toolpath components.  Currently the only way is to re-import a new model, or hope you recently saved.
-View normal to closest nearest plane, similar to Solidworks.
Message 64 of 116
rob_carri
in reply to: Goffa_
It would be very good, that when you wrote a note or some edition, that next to the script you get the same symbol, so you know that this trajectory has something written
Message 65 of 116
iamcdn79
@zfreitas wrote:
Just a tip... on your last wish set the links to Safe and you will get one CYCLE for all similar holes. Using skim the you will get one CYCLE per hole.
I tried that and still get a CYCL DEF for every similar hole
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 66 of 116
We have used other software in the past and one of the paths we miss in Power Mill is a Helicoidal mill.  Basically it is a spiral helix that cuts a flat bottom with the option to add cutter comp.
Message 67 of 116
iamcdn79
There is an option added for that in the pattern curve editor
Windows 11 Pro
Message 68 of 116
GlennM.MCAM
Project preview on last saved state would be very usefull. Also for importing CAD models.
Intel i7 4790 @ 3.60GHz -16GB RAM - Nvidia Quadro K620 - 250GB SSD - Win 7 Pro x64 SP1
PowerMILL Premium 2019.1 - PowerINSPECT Ultimate OMV 2017 SP6
Message 69 of 116
in reply to: iamcdn79
I didn't see that option in the pattern finishing. I was really thinking that having a path in the curve machining would be better. The path in our previous software all you needed a circle to machine on tell it a depth and give it a step down. No need to make a helix to cut on. I have yet to try that pattern helix but are you able to add cutter comp?
Message 70 of 116
iamcdn79
You can add cutter comp in your NC Program settings
Windows 11 Pro
Message 71 of 116
NanchenO
If you use the drilling function, there is a cycle type option helical.
If you deactivate the output as a cycle, you can activate the cutter compensation... or your postprocessor and your machine can handle it within an equivalent cycle with cutter compensation.
I think, that it's exactly what you are looking for ?
Olivier
Message 72 of 116
iamcdn79
Why are all of these videos set to private?
Windows 11 Pro
Message 73 of 116
clinton.perry
Hi @iamcdn79 - apologies, these videos were accidentally uploaded to the AKN. We're busy preparing the 2018 versions of PowerMill, PowerShape etc. for our customers and will share the finished videos with you as soon as possible. Until this time, the videos have been removed from AKN.
Thanks for your patience and sorry for any inconvenience this may have caused.
Message 74 of 116
stdpattern
To add to the list of what I would like to see:
Surface inspection mode like in PowerSHAPE.  I find that very useful, and it would save me from opening up the model just to check some draft angles or fillet radii.
Message 75 of 116
M_Hennig
in reply to: stdpattern
I would pay double my maintenance costs if powermill could make an along corner toolpath that did not do this on 99 percent of the ones it currently calculates.
Message 76 of 116
stdpattern
in reply to: M_Hennig
While we're at it, I don't think  Corner Clearance toolpaths are 100% yet either.  No examples right now, but I don't think It was too long ago that I tried it and it didn't work right.  Adds paths where there don't need to be any.
Steve
Message 77 of 116
cory_marty
I'd like to see a toolpath overlap distance when using  "Machine stock only" on all toolpaths that support machining of stock only.  Exactly how corner detection works when using corner finishing toolpaths.
Message 78 of 116
TK.421
if chunks of a stock model are no longer connected to the main part (corners and such that are floating in space), I'd like the ability to window over them and delete them...
the numbers never lie
Message 79 of 116
Pijetro
in reply to: TK.421
And since you're on the topic of Stock Models...
Perhaps any Rest roughing calculations be contained within the Block or Boundary, rather than running throughout the WHOLE stock model..
Would definately speed up the process..
Message 80 of 116
GlennM.MCAM
in reply to: Pijetro
And pleeeaaase try to calculate it faster. I upgraded from 2015 R2 to 2017 and the calculation of a rest stock model takes a lot longer, even with a higher tolerance.
