postprocessor error - broken connection
Message 1 of 12
we've been using the same post for years and all of a sudden I get this error message:
Write NC Program
Cannot load Counter Name data because an invalid index '' was read from the registry. Complete
Write NC Program
NC program : C:/Fagor/WinDnc/WORK/saddle rough_1.pim
Toolpath saddle rough_1
Unable to Postprocess.
does anyone know what this is and how to correct it?
Replies (11)
Message 2 of 12
NanchenO
If it only happens with one program, then you have a mistake in the program itself.
Could you try to post an older program, which was OK last time ?
Olivier
Message 3 of 12
yes, I already tried that. it gives me the same error message.
i did see a answer to someone else who had the same issue. but i'm waiting to see if there is another answer that doesn't make me make changes to my computer in "administrator" mode.
thanks
Message 4 of 12
NanchenO
Did you try to post to another location (C:\temp) or whatever ?
If you have an IT central service as we have, the most frequent solution to my problems is the answer to: "What the Hell did they change this time ???".
Olivier
Message 5 of 12
i think it's my workstation, i had one of my programmers post from his workstation and it works.
i'm going to contact our IT guys to make sure before i start messing with my workstation.
thanks for the comments, i'll post the results when/if i get this resolved.
Message 6 of 12
well it didn't go so well. now i get this error:
Write NC Program
Category does not exist.
Complete
Write NC Program
stay tuned...
Message 7 of 12
NanchenO
Do you have the opportunity to use another postprocessor (a sample, for instance) ?
Message 8 of 12
yes, i've tried a couple different posts that we have. even tried posting toolpaths that we've already used.
no luck.
Message 9 of 12
Update...
The problem was not updating the post processor utility.
All is well.
Message 10 of 12
cory_barrette
Hello @Anonymous,
I'm glad we were able to figure out this issue!
Cheers,
Cheers,
Cory B
Applications Engineer
Autodesk Manufacturing
Message 11 of 12
Hi
I have a same problem :
Error: Broken connection" when post processing NC code with PMOPTZ(*.pmoptz)
In version 2010 but
I installed older than 2010 version on PC
the older works
but in 2010 i got this error :IMG_20190106_182437.jpg
Message 12 of 12
barr.jarryd
Chances are that your post is out of date. Either that or you need to update your post processor.
Thank you
Jarryd Barr
