I am getting an error when I try to post almost anything. These are programs I've already posted. All I want to do is change some feed rates. I am getting an error.......Postprocessor error-Broken connection. Any help would be greatly appreciated.
Solved by bwatts. Go to Solution.
Restart for the fifth time may have done it. Tech support got on app share and it worked.
I had that problem before not too long ago. I use the duct post still and had a dongle for a license. With PM 2017 I didn't need the dongle anymore to run powermill. However, in order to use the duct post which 2017 doesn't have anymore, I needed the dongle licence plugged in to run the 2016 PM duct post.
Actually I have fixed this. I was low enough on disk space and the programs were too large to fit so that's why it was stopping. It wasn't the post causing the issue. Thank you for everyone's help.
like i told you got the same problem some time ago searched for a problem half an hour. good to hear that go it running now to.
