Post Modification
Post Modification
newgentooling
Post Modification
newgentooling
Dear Sir,
                  We Request Some Post Modification
1) We Required High Speed Command.
Using Finishing Type Toolpath Only High Speed Command Required
Other Type Of 3D Area Clearance, Curve  Machining, And Drilling Toolpath High Speed Command Not Required(Refer Attachment)
Sean571
This is a request that would be more suitable to ask for your powermill reseller to do for you as I doubt anyone here is going to make this change for you. Now if you try to make the change yourself and ask a few questions to point you in the right direction, then people might help you, but even still you should just contact whoever you buy powermill through and request a post modification with them.
Sean Wroblewski
Applications Engineer
newgentooling
Dear Sir,
             We Are Generate High Speed Command Done.
             We Request You High Speed Command Create Finishing Toolpath Only. Other Toolpaths (3D Area Clearance,
Curve Machining And Drilling) Not Required.
Please Refer The Attachment
