please help with macro
romanov-kovrov
romanov-kovrov
FOREACH tp IN folder('Toolpath') {
ACTIVATE TOOLPATH $tp.Name
STRING NewName = replace(Name, 'DRAFT', 'FINAL')+'...'+limits('toolpath','')[4]
RENAME TOOLPATH ; $NewName
1.help me modify it to round or leave 2 digits after the point like 0.00
2. tell me a macro to rename all Toolpaths at once, delete everything to the right of ... dots, thanks
iamcdn79
This rounds to 2 decimal places.
    REAL zVal = round(limits('toolpath','')[4]; 2)
    STRING NewName = replace(Name, 'DRAFT', 'FINAL') + '...' + $zVal
I don't understand your renaming request. you want to delete  the z min limits that were added to your toolpath name? Thats what is to the right of the dots.
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
romanov-kovrov
yes, you understood everything correctly, before you write to delete the values, if I recalculate TOOLPATH and run the macro again it turns out like this, which can be confusingimage.png
iamcdn79
    STRING baseName = replace(Name, 'DRAFT', 'FINAL')
    // Remove any existing "...zVal" value from previous runs
    INT lastDotPos = position($baseName, '...')
    IF lastDotPos > 0 {
        $baseName = substring($baseName, 0, lastDotPos)
    STRING NewName = $baseName + '...' + $zVal
Windows 11 Pro
romanov-kovrov
Thank you so much! Everything worked as I wanted.
