Pattern Finishing
Pattern Finishing
jsweatherbie
Pattern Finishing
jsweatherbie
Im making a engraving macro and i cant seem to get the pattern to apply into the drive curve selection box. just remains empty.
ive tired to look at other posts. like one suggested to use this.
$toolpath.Pattern = $patternName
didnt make a selection just left it also blank....
heres my full macro.
DIALOGS MESSAGE OFF
DIALOGS ERROR OFF
//THIS IS COPYED FROM YOUR FORUM POST
//READ ABOVE JAMES
RESET LOCALVARS
//USER CHOOSES TOOL
STRING userTool = INPUT ENTITY Tool "Choose a Tool for Engraving"
FORM RIBBON BACKSTAGE CLOSE IMPORT TEMPLATE PROJECT FILEOPEN "M:\PowerMill\MACROS\TEMPLATES\ENGRAVING.ptf"
ACTIVATE TOOLPATH #
ACTIVATE TOOL $userTool
STRING $patternName = '$tool.name'+''+'ENGRAVING'
if entity_exists('pattern',$patternName) {
 $patternName = new_entity_name('pattern',$patternName)
//TOOLPATH BLOCK
EDIT BLOCK ALL UNLOCK
EDIT BLOCK RESETLIMIT "0.1"
EDIT BLOCKTYPE BOX
EDIT BLOCK COORDINATE WORKPLANE
EDIT BLOCK RESET
EDIT PAR 'UpperLimit.Active' 1
//INSERTS USER SELECTION
EDIT PATTERN $patternName INSERT MODEL
EDIT PATTERN $patternName MERGE
EDIT PATTERN $patternName FLATTEN
RENAME TOOLPATH # "ENGRAVING"
EDIT TOOLPATH ; CALCULATE
DIALOGS MESSAGE ON
DIALOGS ERROR ON
gosmann.andreas
this should work
EDIT PAR 'Pattern' "$patternName"
jsweatherbie
yeah i figured it out like 5 min after posting lol
Thank you !
iamcdn79
i think the problem is your pattern may not be active, try this
DIALOGS MESSAGE OFF
DIALOGS ERROR OFF
//READ ABOVE JAMES
RESET LOCALVARS
//USER CHOOSES TOOL
ACTIVATE TOOLPATH #
// Create unique pattern name
STRING $patternName = $tool.name + "ENGRAVING"
IF entity_exists('pattern',$patternName) {
// Ensure pattern exists + is active
    ACTIVATE PATTERN $patternName
} ELSE {
    CREATE PATTERN $patternName
// Noe assign it to toolpath
//TOOLPATH BLOCK
EDIT BLOCKTYPE BOX
EDIT BLOCK RESET
DIALOGS MESSAGE ON
DIALOGS ERROR ON
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
