PAF Error = 4 Line = 8191 Powermill 2016
Message 1 of 13
Hi, I had power mill with dongle running on the PC . Due to hard disk crash I have installed powermil 2016. But when I run it, gives error "PAF =4line = 8191 please contact your system supplier for valid PAF". I could not find PAF on my pc please help me with this.
Replies (12)
Message 2 of 13
stheroux
If you didn't have a backup of your *.paf you will likely have to contact Autodesk. I would imagine they could still get you a copy of your last *.paf that was issued to you before they did the switch to the flexnet hasp.
Message 3 of 13
Thanks for your response. Please tell me how to contact Autodesk in order
to get a copy of PAF. Because I don't have the one.
Message 4 of 13
Jonathan_Artiss19
Do you know who your Delcam sales manager is? Do you have an Autodesk Account?
Can you search your email for a PAF license file?
Jonathan Artiss
Senior Applications Engineer | DSI
Autodesk Expert Elite member
DSI, Design and Software International Autodesk Gold Partner
Message 5 of 13
No, unfortunately we don't have any of these information. Nobody is aware
about this and I am also new here in this organization.It was first
installed in 2012. Please help me to fix it.
Message 6 of 13
Jonathan_Artiss19
Im not sure who the contact would be for your area, you could try looking up the Autodesk office in your area and calling.
You may be able to find some information here as to how to reach support. https://www.autodesk.com/company/contact-us
ithout your PAF license, there is nothing that the forum community can do to help you.
Jonathan Artiss
Message 7 of 13
Hi, I have the dongle which was provided by delcam and I suppose it is
working. What is this dongle used for?
Message 8 of 13
Jonathan_Artiss19
The dongle and the license file work together to activate PowerMill. If you lose one of these elements, the software will not work.
Jonathan Artiss
Message 9 of 13
stheroux
Unfortunately I don't know who you would contact as @Jonathan_Artiss19  said you would likely have to contact your local Autodesk office / Reseller.
Maybe your IT person would have backups of original drive that failed on you?
All else fails
Have you tried to mount the 'failed disk' to retrieve data, could simply have been a bad boot sector.
If that doesn't work..,
Sounds crazy, but in the past we've been able to put drive in a ZIPLOCK in the freezer overnight, mount it and be able to run it long enough to retrieve data before it got too hot to read.
The file you are needing would likely be in C:/dcam/config/pass/*.paf
Best of luck
Message 10 of 13
Hi, I am the IT person here and could not find back up any where that's why
contacting for your help. The disk drive on which it was installed is not
working, it got completely crashed, no data showing on it. At least can you
tell me the supplier/vendor details in UAE.
Message 11 of 13
Oscar_cadcampilot
@Anonymous ,
Try Deltron ( FZE), it's the only Autodesk reseller that's listed in the Autodesk Partner Locator at https://www.autodesk.com/partners/locate-a-reseller
http://www.deltronme.com/
They might be able to help.
Oscar
cadcampilot
Message 12 of 13
kvscastings
Community Visitor
Community Visitor
please help me
Message 13 of 13
christopher_marion
@kvscastings
Can you elaborate what you need help with?
Christopher Marion
Autodesk Canada
