Okuma OSP post
Okuma OSP post
instrumakr
Okuma OSP post
instrumakr
Hello All
Does anyone have an Okuma osp post  that they can share.
The machinist that run the okuma"s typically use gibbscam.
But there are occasions where they can not  get the desired toolpath
for surfacing. If I could post code for them on occasion it would
be a big help. I would hate to start from scratch on a post for them.
Any help appreciated.
Thank You
Instrumakr
jonathan.artiss
Hi @instrumakr
Thank you for posting on the Autodesk PowerMill Forum!
@instrumakr wrote:
Hello All
Thank You
Instrumakr
There is a generic Okuma OSP post found in the internal install in the below location. You can test this (In safe conditions) to see if it would work with your machine.
This will likely require modifications depending on your machine setup. If it requires modification, create a case in your Autodesk Account for the post team.
C:\Users\Public\Documents\Autodesk\Manufacturing Post Processor Utility 2018\Generic
Cheers,
Jonathan Artiss
Application Engineer
Submitting & Viewing Support Requests | Web Support | Phone Support
