Offset each segments boundary in PowerMILL 2015
hx
hx
At PowerMILL 2015.
I Wrote an macro file to offset each segments boundary for 2 mm.
The macor commands are:
STRING $Active_Boundary = Boundary.Name
INT $NO_OF_SEGMENTS = SEGMENTS(Boundary)
INT $Select_Segment = 0
DO {
EDIT BOUNDARY ; DESELECT ALL
EDIT BOUNDARY ; SELECT $Select_Segment
EDIT BOUNDARY ; CURVEEDITOR START
CURVEEDITOR MODE OFFSET
MODE TRANSFORM OFFSET DISTANCE 2
CURVEEDITOR FINISH ACCEPT
$Select_Segment = $Select_Segment+1
} WHILE $Select_Segment < $NO_OF_SEGMENTS
But when I run the macro file, the problem is not do loop for each segments boundary. only two esgments. just like the image show.
when the $Select_Segment > 2 , the selected one is the arrow points to the line segment.
How can I fixed this macro?
hx
Upload the project files and macro.
kukelyk
Try this:
DO {
EDIT BOUNDARY ; SELECT 0
The new offset curve will be the last..
hx
Perfect. thanks.
