Nvidia Settings - Optimization
Goodmorning;
My shift-opposite programmer is complaining that his machine is bogging down doing some fairly basic operations. I don't experience them but I don't do similar work.
I'd like to see if there are maybe some tips or tricks to get everything to flow better on these Quadro cards. We had to do a work-around to get setup sheets working (the 3d app - visual simulation check box) so I wonder if we are just poorly optimized.
Specs are as follows;
[Display]
Operating System: Windows 10 Pro, 64-bit
DirectX version: 12.0
GPU processor:  Quadro M4000
Driver version:  377.48
Direct3D API version: 12
Direct3D feature level: 12_1
CUDA Cores:  1664
Core clock:  772 MHz
Memory data rate: 6010 MHz
Memory interface: 256-bit
Memory bandwidth: 192.32 GB/s
Total available graphics memory: 24531 MB
Dedicated video memory: 8192 MB GDDR5
System video memory: 0 MB
Shared system memory: 16339 MB
Video BIOS version: 84.04.88.00.06
IRQ:   Not used
Bus:   PCI Express x16 Gen3
Device Id:  10DE 13F1 115310DE
Part Number:  G400 0501
iamcdn79
Try using the settings in the attached pics
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Seems to work well for me, I've noticed some increased speed so hopefully it'll carry over.
Are there any other optimizations that I should be doing? I think a lot of it may be our fixture models being overly heavy on the surfaces (3000+ surfaces for jig plate is...suboptimal.) but if there are other easy fixes I'm all for them.
iamcdn79
What format are those files written out in? Try .dmt, or .dgk
Windows 11 Pro
