Needing macro help with proper use and reference of $tool.type ....,
stheroux
Message 1 of 24
stheroux
Using tool.xml user menu with multiple selection function, I am stuck on how to find all $tool.types in folder 'tool'.
Then based on results, create individual folders (eg. BallNose, TipRad, TippedDisc....,) for found $tool.types and move each tool.type to corresponding tool.type folder created.
Replies (23)
Message 21 of 24
Some Powermill commands do not work well with variables, in which case the DoCommand statement should be used.
Please run  the next example  in debugger step by step:
STRING T=folder('tool')[0].Name
ACTIVATE TOOL $T // -working
DELETE TOOL $T // -working
EDIT RECYCLER RECOVER Tool $T // -working
FORM TOOL $T  // -not working
// Use instead the next sequence
STRING CMD="FORM TOOL '"+$T+"'"
DoCommand $CMD // -working
Message 22 of 24
stheroux
I ran both instances and they both work perfect!
Selects first tool, deletes it, recovers from trash and raises the tool form.
Message 23 of 24
stheroux
If you are running this to remove tools from a folder, it does not work if tool has been used.
If you use tool.xml user menu, add this macro to it.
Select all tools you want to remove and run macro through user.xml
Function Main( STRING $Selected ) {
STRING LIST $ToolNames = {}
CALL Get_Tool_List($Selected, $ToolNames)
STRING $FULL = ''
STRING $DIR = ''
DIALOGS MESSAGE OFF
FOREACH $T IN $ToolNames {
$FULL = $pathname('tool', '$T')
$DIR = $dirname('$FULL')
EDIT FOLDER $DIR REMOVE $T
Function Get_Tool_List(
STRING $Selected
OUTPUT STRING LIST $Selected_Tools
If $powermill.Status.MultipleSelection.total == 0 OR $powermill.Status.MultipleSelection.First {
IF NOT member(project._keys,"Multiple_Selected_Names") {
EDIT PAR CREATE STRING "Multiple_Selected_Names"
$Project.Multiple_Selected_Names = ""
} ELSE {
$Project.Multiple_Selected_Names = $Project.Multiple_Selected_Names + "\"
$Project.Multiple_Selected_Names = $Project.Multiple_Selected_Names + $Selected
IF NOT($powermill.Status.MultipleSelection.Last or $powermill.Status.MultipleSelection.total == 0) {
MACRO ABORT
$Selected_Tools = TOKENS($Project.Multiple_Selected_Names, "\")
Message 24 of 24
The next code working  (PM2017)
FUNCTION Main( STRING $Selected ) {
   STRING $FULL = ''
   STRING $DIR = ''
   DIALOGS MESSAGE OFF
      $DIR = $dirname($FULL)
      IF $DIR != 'Tool' {
         STRING Cmd="EDIT FOLDER '"+$DIR+"' REMOVE '"+$T+"'"
         DoCommand $Cmd
FUNCTION Get_Tool_List(
STRING $Selected
   IF $powermill.Status.MultipleSelection.total == 0 OR $powermill.Status.MultipleSelection.First {
   } ELSE {
      MACRO ABORT
Same result, but shortest:
   STRING $DIR = $dirname(pathname('tool',$Selected))
   IF $DIR != 'Tool' {
      STRING Cmd="EDIT FOLDER '"+$DIR+"' REMOVE '"+$Selected+"'"
      DoCommand $Cmd
