We recently took on overflow work from a customer and there workplanes are in the right spot but its not in world position. I know how to do it manually in powermill but i was wondering if you can do it with a macro instead? Any help would be great, thanks!
Solved by richard.pedley. Go to Solution.
Something like:
ACTIVATE WORKPLANE ${Folder('workplane')[0]} TRANSFORM RESET TRANSFORM TYPE WORLD TRANSFORM MODEL ALL
Should work.
Hope that helps
Richard
HI !
how could I do it for multiple models in the project.
Suppose I have 10 models in the same project.
So, How can I use FOREACH or WHILE or LOOP command ?
Thanks ,
