Need macro command for a set value in the surface default tab
iamcdn79
Mentor Mentor
iamcdn79
I am trying to make a macro that takes a set value from the surface default tab of set 5 and uses the radial thickness value only as my curve thickness for 2D curve Profile but I get an error.
I don't know what that command would be and if it would be REAL or STRING.
Real overburn= EDIT THICKNESS DEFAULTLIST UPDATE\r 5 NEW
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "Curve-Machining/2D-Curve-Profile.003.ptf"
EDIT PAR 'CurveThickness' $overburn
EDIT PAR 'Tolerance' ".001"
EDIT PAR 'AreaClearance.Rest.Active' '0'
EDIT PAR 'AreaClearance.Profile.CutDirection' 'climb'
EDIT PAR 'Thickness' "0"
STRING pattern = $entity('pattern','').name
$toolpath.Pattern = $pattern
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
kukelyk
As I remember, the last row can cause error, instead of
 try
EDIT PAR "Pattern" $pattern
 at least older versions of pmill.
old_snickers
I found something interesting here by looking for how to capture the RGB-values of a surface...
Try this instead of your first line:
REAL overburn = 0
// Capture the value using a tracefile into file C:\Temp\thickness.txt
ECHO OFF DCPDEBUG UNTRACE COMMAND ACCEPT
TRACEFILE OPEN "C:\Temp\thickness.txt"
PRINT formvalue Thickness.Shell.ThickDef.Radial
TRACEFILE CLOSE
// Read the first line of the Tracefile into variable $overburn
FILE OPEN "C:\Temp\thickness.txt" FOR READ AS input
FILE READ $overburn FROM input
FILE CLOSE input
kevin.hammond3WX4X
Replace your first line with this
Real Overburn = $widget("Thickness.Shell.ThickDef.Radial").value
iamcdn79
 try
In 2023 that's no problem
Windows 11 Pro
old_snickers
That's very much cleaner 👍! Tomorrow I'll try this method with my RGB-issue also.
