Hi @Alir3za
I just used the edge of the part and created a composite curve. I then offset it inward until I got the tool axis to behave on how I want. Trial and error really.
As for roughing this part. The safest method is to remove as much material in 3 axis and then tip in different orientations in 3+2 using a stock model. In you case, maybe do it in 90 degree segments or even 45 degree segments. This would involve quite a bit of toolpaths, workplanes and boundaries.
I did it a bit different, just to show you some options. If you look at the attached project, I first created some stock to just focus on the undercut groove. Then I created the following toolpaths:
- Rough Straight - 3d model area clearance to machine in 3 axis.
- Rough 5 axis 1 - Swarf toolpath with multiple cuts leaving 1/8" stock on the undercut
- Rough 5 axis 2 - Swarf toolpath with multiple cuts leaving 0.01" stock on the undercut
- Rough 5 axis 3 - Projection surface finishing toolpath that machines along the pattern going from out to in leaving 0.01" stock. You may even want to clone this toolpath with a smaller cutter and focus towards the bottom of the undercut.
- Projection_Surface_Finishing - This is the toolpath I sent you the other day.
I ran this through Viewmill, and it seems doable. I had a few warning of rapid moves into stock, but this warning can be misleading.
Hope this is a good starting point anyway. I did this quickly, so I am sure you will put your own twist on it.
Love to see some finish pictures of this part.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
