Need detail instructions to create new robot MTD file
I am trying to add a DENSO V087 robot to PowerMill.
Is there video instruction on how to create a new *.dmt file? The steps shown in the PDF isn't really clear on what and when to create names (like A.dmt or Spindle.dmt).
In section 2.3, how do you "move" the spindle to the correct position? Is it using the Assembly -> Attachment function? What do you do when you encounter the "You do not have the necessary license to use Assembly modelling"? Can you, say, assemble the robot in SolidWorks or Fusion360 in with *.stp files, export, and re-import into PowerShape? Will it maintain the correct coordinates?
Are you suppose to assemble the spindle on the robot model before using PowerMill?
If you have a mounting plate between the tool mounting flange and spindle, how do you handle it? May be "attach" it to the spindle model? Should it be done outside PowerShape then (i.e. assemble them in SolidWorks first), then import both as one model into PowerShape?
Is the *.dmt file the graphical parts? Is the *.mdt file the parameter for the robot? It isn't clear on p.13 of the "How to build a Robot simulation" that the *.mdt is part of the export and "contains triangles", and then you need to edit it in notepad following the steps in section 4.3.
Can you also clarify the steps in section 4.3 about modifying the folder name and the naming convention?
Do you also have a Robot Setup - xxx.pdf for DENSO robots?
In Section 4.3, it mention you need to update 2. Heat attachment point. In Section 4.5 Tool and Table Attach Points, it is describing to update the description of the head_attach_point. Is the tool same as head? Or is it describing where the tool is going to attach to the head?
Any pointers will be greatly appreciated.
Ray
