NCProgram User Defined Parameter value for use in setup sheets
artemis8ZPLP
artemis8ZPLP
Hello everybody !
I've created a User Defined Parameter named Cutter_Compensation_Left_State.
This Parameter Gets values (ACTIVE or NOT-ACTIVE)
according to Cutter, Compensation Value see attached Image Capture_x.
I want to get the User Defined Parameter, Cutter_Compensation_Left_State, VALUE in HTML in order to use it in Setup-Sheets creation.
Thank you !!!
iamcdn79
Try {CNCCutterCompensation.Active} or {CNCCutterCompensation.Type}. Not sure which one you want.
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
