NCPROGRAM Management
Felipe_Callegario
Message 1 of 10
Felipe_Callegario
I would like some help with my macro, I want to make it activate the work plane according to its respective NC program.
ENTITY LIST $Selected_ncprogram = INPUT ENTITY MULTIPLE ncprogram "Selecione Programa"
EXPLORER SELECT NCPROGRAM root
FOREACH $nc in $Selected_ncprogram {
STRING $full_path = pathname('ncprogram',$nc.name)
EXPLORER SELECT NCProgram $full_path TOGGLE
FOREACH ent IN explorer_selected_entities() {
STRING $SNAP_ncp = project_pathname(0) + "\SetupSheets_files\snapshots\ncp-x" + $entity("ncprogram", $ent.Name).id + ".png"
IF file_exists($SNAP_ncp) {
DELETE FILE $SNAP_ncp
DIALOGS MESSAGE OFF
//DEACTIVATE WORKPLANE
//ACTIVATE WORKPLANE FROMENTITY NCPROGRAM $ent.Name
DIALOGS MESSAGE ON
EDIT MODEL ALL DESELECT ALL
DEACTIVATE NCPROGRAM
ROTATE TRANSFORM TOP
UNDRAW NCPROGRAM ALL
DEACTIVATE TOOLPATH
UNDRAW TOOLPATH ALL
DEACTIVATE TOOL
UNDRAW TOOL ALL
DEACTIVATE BOUNDARY
UNDRAW BOUNDARY ALL
DEACTIVATE PATTERN
UNDRAW PATTERN ALL
DEACTIVATE FEATURESET
UNDRAW FEATURESET ALL
UNDRAW AXES
UNDRAW BLOCK
IF entity_exists("Workplane",'$ent.Name')>1 {
MACRO PAUSE "Posicione a vista"
//DRAW NCPROGRAM_PATHS $ent.Name
STRING $cmd = 'KEEP SNAPSHOT NCPROGRAM "' + $ent.Name + '" CURRENT'
DOCOMMAND $cmd
UNDRAW NCPROGRAM_PATHS $ent.Name
GRAPHICS UNLOCK
} ELSE {
DOCOMMAND $cmd
Replies (9)
Message 2 of 10
LasseFred
Use this:
$entity('NCProgram','$Nc.name').OutputWorkplane.Name
______________________
Lasse F.
Message 3 of 10
Felipe_Callegario
Thanks for your reply but could you help me where should I put it
because I'm replacing and it's giving this error.
This one :
Message 4 of 10
nguyenthinhvt95
Hi @Felipe_Callegario
It think you should try:
IF entity_exists("Workplane",'$ent.Name') {
Instead of:
Message 5 of 10
LasseFred
Try this:
there might be some errors. i made it on my phone
			DIALOGS MESSAGE OFF
			DIALOGS MESSAGE ON
			DEACTIVATE TOOLPATH
			UNDRAW TOOLPATH ALL
			DEACTIVATE TOOL
			UNDRAW TOOL ALL
			DEACTIVATE BOUNDARY
			UNDRAW BOUNDARY ALL
			DEACTIVATE PATTERN
			UNDRAW PATTERN ALL
			UNDRAW AXES
			UNDRAW BLOCK
		STRING $NCWORKPLANE = $entity('NCProgram','$ent.name').OutputWorkplane.Name
		IF $NCWORKPLANE > "" {
		//IF entity_exists("Workplane",'$ent.Name')>1 {
		ACTIVATE WORKPLANE $NCWORKPLANE
		DOCOMMAND $cmd
		GRAPHICS UNLOCK
		} ELSE {
		DOCOMMAND $cmd
Lasse F.
Message 6 of 10
Felipe_Callegario
Thanks for the answers, but it is still not activating the corresponding workplane.
Message 7 of 10
LasseFred
It works fine here.
Do you have a NC-Workplane in your NC-Program?
Lasse F.
Message 8 of 10
rafael.sansao
FOREACH ent IN $Selected_ncprogram {
	DIALOGS MESSAGE OFF
	DIALOGS MESSAGE ON
	DEACTIVATE TOOLPATH
	UNDRAW TOOLPATH ALL
	DEACTIVATE TOOL
	UNDRAW TOOL ALL
	DEACTIVATE BOUNDARY
	UNDRAW BOUNDARY ALL
	DEACTIVATE PATTERN
	UNDRAW PATTERN ALL
	UNDRAW AXES
	UNDRAW BLOCK
	FOREACH item IN components($ent) {
		IF lcase(item.RootType) == "nctoolpath" {
			IF NOT ERROR($entity("Toolpath", $item.Name).Workplane) {
				STRING $wpName = $entity("Toolpath", $item.Name).Workplane.Name
				ACTIVATE WORKPLANE $wpName
				DOCOMMAND $cmd
				GRAPHICS UNLOCK
			} ELSE {
				DOCOMMAND $cmd
			BREAK
Rafael Sansão
OptiNC - www.optinc.tech
Message 9 of 10
Felipe_Callegario
Thanks a lot @LasseFred , @nguyenthinhvt95 , who took the time to help me, thanks @rafael.sansao , for your solution, now it's doing what I wanted
Message 10 of 10
ramaprasad_narayan
i need a help with this macro to pause each toolpath.
could you please help me
FOREACH pg IN folder('NCProgram') {
ACTIVATE NCProgram $pg.Name
KEEP SNAPSHOT NCPROGRAM ; ALL CURRENT_VIEW
TEXTINFO ACCEPT
at the moment it is running continually. i want to pause(MACRO PAUSE " VIEW OF THE TOOLPATHS IS OK?")
snapshot required including toolpath with custom view.
thank you.
Ramaprasad
