NC program coolant problem
chrisKDR3N
chrisKDR3N
HI all
in powermill 2017, i can choose multiple paths,then change coolant option.
but in 2020 ~ 2023,i can't do the same way.  i have to change coolant one by one. it take a lot of time.
the picture above is  PM 2021. You can't change  the coolant option while choose mutiple path.
this one is PM 20217, I can change muti toolpath's coolant at the same time.
if i want to change mutiple toolpath's coolant at the same time, how can i do that.
nguyenthinhvt95
Hi @chrisKDR3N
I have no idea to change the coolant for multiple toolpaths in NC program
But you can change the coolant in the toolpath before create the nc program.
I have a macro that can do that easily, you can use it for references
chrisKDR3N
HI @nguyenthinhvt95
thanks for the marco,it's help a lot
But i'm wondering why autodesk change this.
this function is useful when i want to change coolant in NC program
dans4DQYP
See This
https://forums.autodesk.com/t5/powermill-forum/2019-1-1-bug-changing-coolants-in-ncprograms/m-p/8243...
I asked for this fix back in 2019   Autodesk has really failed on fixing this one !
