Dear all.
I am using PowerMill Premium 2020.
Can you help Me, for creating macro/setting template for avoid error when post NC Program.
These setting sometimes change when i unknowingly drive a mouse, resulting in a different NC fileor not safe if i run to machine.
Setting parameters as shown picture bellow.
Thanks.
Solved by Jonathan.Artiss-DSI. Go to Solution.
Here are the macro commands in text form for the NC preferences. If you are changing this by accident in the NC program settings, you would need a different macro to set these back.
EDIT NCPROGRAM PREFERENCES PROJECT OFF
EDIT NCPROGRAM PREFERENCES FILEMODE 3PLUS2
EDIT NCPROGRAM PREFERENCES TOOLCOORDS TIP
EDIT NCPROGRAM PREFERENCES CONNECTION SIMULTANEOUS
Jonathan Artiss
Senior Applications Engineer | DSI
